rebuilding cable transmission
Old Aug 27, 2006 | 05:33 PM
ef 4 door's Avatar
Default rebuilding cable transmission
i need some information on how difficult it is to rebuild a cable tranny. I have a ls out of a 93 integra and a b16 tranny out of 93 gsr. both of them have 3rd gear out. I want to rebuild them the right way, not just bits and pieces.
Old Aug 28, 2006 | 07:12 PM
91' LS-VTEC's Avatar
Default Vote for Perdo.
So your looking to rebuild BOTH tranny's? As far as the "rite way" do you meen back to stock? If you going to rebuild them contact Gearspeed, for prices and parts, they might be able to help.Cable tranny's are getting harder and harder to find. You might just want to spend $500 and get a new(used) one. Sometimes HMotors has them in stock. If all else fails, /yourself.
Old Aug 28, 2006 | 10:36 PM
ef 4 door's Avatar
Default Re: rebuilding cable transmission (ef 4 door)
I want to rebuild them to stock, yes is correct. if posible if may want more. I do know that stock cable tranny are too find. i will kow more this in a couple days when I break into them. I plan to have my ls tranny to use in a turbo set-up and my gsr tranny in street use.
Old Aug 28, 2006 | 10:42 PM
Tippyman's Avatar
Default Re: Vote for Perdo. (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">So your looking to rebuild BOTH tranny's? As far as the "rite way" do you meen back to stock? If you going to rebuild them contact Gearspeed, for prices and parts, they might be able to help.Cable tranny's are getting harder and harder to find. You might just want to spend $500 and get a new(used) one. Sometimes HMotors has them in stock. If all else fails, /yourself. </TD></TR></TABLE>
HMO has them for $150. But shipping will be a bitch, lol.
Old Aug 28, 2006 | 11:18 PM
Tyson's Avatar
theres informaton in the faq.
Old Aug 31, 2006 | 01:07 PM
ef 4 door's Avatar
Default Re: Vote for Perdo. (Tippyman)--HMO???
who exactly is hmo and where can i get in contact wit them.
Old Aug 31, 2006 | 01:08 PM
ef 4 door's Avatar
Default Re: rebuilding cable transmission (Tyson)
you said that there is information on the faq, I had some difficultly in trying ot find information in the faq? in any information would be great!
Old Aug 31, 2006 | 01:12 PM
Tyson's Avatar
Transmission and Axle
How to Identify Si, DX and HF L3 transmission
How to take off transmission and Inspect Input Shaft Bearing
*Honda Transmission Gearing
*B Series Tranny Specs
*Tranny Calculator
*CRX Math (another tranny calculator)
Axle Replacement Tutorial With PICS!
*Notes about JDM L3 (DOHC) "ZC tranny"
LS 5th Gear Install guide! JDM B16 S1
*CRX WORLD Transmission Rebuild
Discontained's Avatar
http://hmotorsonline.com/shop/
Old Aug 31, 2006 | 01:22 PM
ef 4 door's Avatar
hey thanks a whole lot, I will look over the the links and start on the rebuilding process.
Old Aug 31, 2006 | 01:31 PM
si90rex's Avatar
if u have both trannys i would put the ls's 5th gear in the b16 tranny because, the gears are so short in a b16 that highway speeds suck for gas mileage. u can get carbon syncros from gearspeed and any thing else u need from them.
Old Sep 2, 2006 | 06:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
HMO has them for $150. But shipping will be a bitch, lol.</TD></TR></TABLE>
Who did you talk to? I've called before,and they quoted me $500. Are you talking about a B16 tranny, or a LS tranny?
ef 4 door : have you started on the tear down yet?
Old Sep 5, 2006 | 09:15 AM
Boosted_92's Avatar
suscribing, I need similar info.
Old Sep 5, 2006 | 12:50 PM
90civichbsi's Avatar
Default Re: Vote for Perdo. (Boosted_92)
If your going to rebuild it just go ahead and buy the syncro sleeve kits. from my expirience, the syncros arent usually the most worn parts on a honda tranny. The syncro sleeves usually get rounded off.
with the syncro hub kits (which gearspeed and honda both sell) you get the syncro sleeve, hub and syncro. They come in sets of 1-2, 3-4 and 5th gear. you wont always need the 5th gear set but the first 4 are usually pretty shot in and older cable tranny.
just thought id give you a little heads up... the first tranny i did i just bought the syncros for it. took it apart and realized i needed the syncro sleeves as well.. which could only be bought in a set.
your better off rebuilding than buying another trany that will prolly be just as bad in a couple years
Old Sep 5, 2006 | 05:18 PM
Wes V's Avatar
Default Re: Vote for Perdo. (90civichbsi)
<U>Buy the factory manual for each transmission you are going to work on.</U>
Take the transmission apart and then contact Gearspeed (James) and get a price quote for the parts you need.
On some transmissions, Honda doesn't sell just a syncro sleeve; it comes with the gears as a set and that adds up the price real quick.
What I'm getting at is that you should be prepared to have cost go beyond what the transmission is worth.
So, have a dollar amount in mind as to what it's worth.
Wes
Old Sep 5, 2006 | 05:30 PM
Tippyman's Avatar
ef 4 door : have you started on the tear down yet? </TD></TR></TABLE>
sorry, ZC tranny.
Old Sep 5, 2006 | 05:54 PM
lightcrx's Avatar
id ull apart so trannys at the local u pull it and get a feel for it.... mightest well get some internal tranny parts to. look for good syncros and sleves
-joseph
Old Sep 5, 2006 | 07:21 PM
jpciii's Avatar
Default Re: Vote for Perdo. (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote"><U>Buy the factory manual for each transmission you are going to work on.</U>
Wes</TD></TR></TABLE>
for wisdom
Old Sep 6, 2006 | 02:57 PM
ef 4 door's Avatar
Default have you started on the tear down yet? (91' LS-VTEC)
I have started the tear down last night with both of my trannys have been worn down. the b16 tranny is ok but need the gear replaced, the teeth have some wear. what year is the tranny....ie make and model for the proper rebuild info!
also the ls tranny has busted bearing (both)where the syncros are at. need to clean the tranny and put in a part washer. in re to the thrid gear wearing out, but not bad
Old Sep 6, 2006 | 03:32 PM
lightcrx's Avatar
what gear in the b16 tranny?
-joseph
Old Sep 6, 2006 | 05:58 PM
ef 4 door's Avatar
Default what gear in the b16 tranny?
third gear, I also been told that if you swithch the diff in the tranny you can get the best of both worlds......my ls tranny will work greta for a turbo set up and the b16 will have such a great close ratio setup. is this true?
Old Sep 7, 2006 | 06:48 AM
lightcrx's Avatar
i think the b16 tranny will be faster. the dif's are the same unless its lsd, the ring gear and fd are differant. b16 has a 4.4 ls has a 4.2, i wouldnt change it. take a pic of 3rd and post it up
-joseph
Old Sep 10, 2006 | 08:54 PM
ef 4 door's Avatar
Default tranny diff gearing
the reaon that I might plan on changing the gearing is because a freind changed his diff with from a ls tranny. he has a gsr and replaced the diff? he pulls a whole lot harder. I will post the pics of my tranny in the nexzt few days.
Old Sep 11, 2006 | 12:13 PM
lightcrx's Avatar
new diff wont improve any thing unless its a lsd or ur was broken, changing the fd is a different story tho
-joseph
Old Sep 11, 2006 | 07:54 PM
Default Re: (lightcrx)
pics?
