what jdm engine will fit in my crx without having to change the wiring harness
Old Aug 27, 2006 | 01:24 PM
crx04's Avatar
Default what jdm engine will fit in my crx without having to change the wiring harness
i was wondering what engine i can use can i use a jdmb16a 1st generation
Old Aug 27, 2006 | 01:26 PM
SVOboy's Avatar
You'd need to add vtec for that. Basically any nonvtec engine I guess, what's wrong with a little wiring here and there?
Old Aug 27, 2006 | 01:29 PM
jhota's Avatar
Default Re: what jdm engine will fit in my crx without having to change the wiring harness (crx04)
depends on the CRX, too. if it's a DX, not much.
Old Aug 27, 2006 | 03:32 PM
philkehn's Avatar
Ya you can put just about any b series or d series engine into your rex and you HAVE TO keep your original engine harness both you chassis and engine and then add your vtec if you go vtec, just simple things here and there, if you use a different harness with your engine the pins for your engine and chassis harness wont like up correctly sending bad signals to all your funtions
CRXTION
May 21, 2017 08:34 PM
MaxsZepeda
Mar 30, 2017 10:13 AM
komet 163
Sep 27, 2016 04:50 PM
CRX_Honda
Nov 14, 2008 05:06 PM
NeWnMpR0VeD
Jan 14, 2006 06:57 PM
