Using TPS off 92-95 DX
Old Aug 27, 2006 | 10:30 AM
efKART's Avatar
Default Using TPS off 92-95 DX
I accidently broke off my TPS sensor on my A6, and I have a 92-95 DX TPS on it right now, but it's still throwing the code. Is it in reverse polarity compared to the original sensor, or what? I did some research and saw people switching wires around, but I don't know which one's to switch. Any help would be appreciated.
Old Aug 27, 2006 | 10:40 AM
e jay one's Avatar
Default Re: Using TPS off 92-95 DX (efKART)
the tps is the same it will work you just have to adjust it if you noticed it can be moved when the bolts arent tight. you need a ohm meter just search here on exactly how to do it. i personaly didnt have that and didnt really care so i just moved it a little until the cel went away.
Old Aug 27, 2006 | 10:49 AM
efKART's Avatar
also, when I put the TPS in, It idles at 3k but when I take it out it idles like it should, around 900-1100 rpms... Anyone know a reason?
Old Aug 28, 2006 | 04:01 PM
e jay one's Avatar
Default Re: (efKART)
adjust it then go from there.
Fine_EF9
Jun 11, 2009 11:38 AM
MelloYelloCRX
May 5, 2007 06:10 PM
shadowstylz
Aug 19, 2003 06:31 PM
CXHatchback
May 27, 2003 09:44 AM
