b21a parting motor out. OE 95mm stroke crank, etc...
Yeah, parting a b21a 1991 prelude motor. Cams are sold. The rest is there. You can use this crank inside an LS engine according to Golden Eagle. Engine is 95mm x 83mm.
Open to trades, no cash required. Not sure on mileage, but this was pulled from a wreck back in 95 and has been gathering dust ever since.
so if you deck plate the block, and use the 95mm crank what rods can you use, to run that crank with that deck plate on the block
