WATER IN HATCH
Old Aug 27, 2006 | 04:36 AM
saikouEF8's Avatar
Default WATER IN HATCH
i have a crx and everytime it rains fairly hard i have to go out and clean my hatch because theres a puddle of water just sitting in it. i cant tell how its getting in. and its usually a lot. the tailights arent watery either. the water is usually under the side rear panells and i have to pull then up to dry out the water in there. this is getting anoying. its not rusted yet but i think it will if tis keep happening. what seal has gone bad???
Old Aug 27, 2006 | 04:56 AM
saikouEF8's Avatar
Default Re: WATER IN HATCH (saikouEF8)
BUMP i know you people know about this.... i cant find **** on ht.
Old Aug 27, 2006 | 05:04 AM
CRX Toad's Avatar
Searching normally helps too. Also might be the gaskets between the body and tail lights.
Old Aug 27, 2006 | 05:10 AM
saikouEF8's Avatar
Default Re: WATER IN HATCH (CRX Toad)
thanks. i couldnt find anything. ill give this a shot... ok, just went outside...my nozzle isnt loose, so how the hell would i fix the hatch hinge? that doesnt even appear to be fouled in any way...
Old Aug 27, 2006 | 07:14 AM
civhatch90's Avatar
there are a lot of threads about this already search. here is one https://honda-tech.com/zerothread?id=1558066
Old Aug 27, 2006 | 09:30 AM
Jonsk20Hatch's Avatar
i have a ef and mine was leaking too but not from the hatch it was from the door strip what would get wet was the passanger front floorboard but everything is ok now has this happen to anyone
Prudz_lude
Feb 8, 2016 11:19 AM
head458
Oct 20, 2009 05:38 PM
bcrosby51
Aug 9, 2007 11:48 AM
JackAcc
Jun 20, 2003 09:10 AM
smacked94gsr
Oct 28, 2002 04:16 AM
