CRX Main Relay Part #
I'll save you the trouble, or at least maybe i will. You can repair your old one. all you need is a soldering iron some solder and time.
take the black cover off the main relay so that the little green circuit board is exposed.
rest the main relay on a work area plug down, so the circuit board is up.
one by one heat up each solder point, when the solder on a point goes liquid add a touch of fresh solder and let it cool, then move onto the next point.
once you have remelted and added a bit of new solder to each point the job is done.
plug it back in and give it a try.
when soldering there are a couple points that look like they will melt together don't worry about this just go slow.
good luck
good luck
