code #7
my friend car is throwing code 7, can you guy check up with team integra to see what that is, or if anybody know.. im thinking is tps sensor, but not really sure, need to be confirm
And you couldn't go here yourself beecause....
anyway, according to http://www.team-integra.net/se...ID=34
7 Throttle Angle
and you can find the codes on this site as well in the FAQ as well;
https://honda-tech.com/zerothread?id=978933
7 TPS - throttle position sensor
Ali
7 Throttle Angle
Ali
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">my friend car is throwing code 7, can you guy check up with team integra to see what that is, or if anybody know.. im thinking is tps sensor, but not really sure, need to be confirm</TD></TR></TABLE>
tps's suck. I hate that you can't buy just the sensor from the dealer.
the point of making the tread is because i try searching and didnt find any result, i kinda knew what it was, but just to confirm to see if it was correct, and if you dont wanan help you dont have too, dont gotta be all that about why i cant do this and that. the point of making this tread is looking for help. so thank.
Check the voltage on the tps. Turn the car to on, if ur cars obd1 check d11 with a multimeter and the voltage should be close to .5V with the throttle closed, and 4.5V when at WOT, if it's not at .5V at idle, then change it till it is, if ur car's obd2, find the correct pin on the ecu to backprobe. Or u can backprobe it from the connector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">the point of making the tread is because i try searching and didnt find any result, i kinda knew what it was, but just to confirm to see if it was correct, and if you dont wanan help you dont have too, dont gotta be all that about why i cant do this and that. the point of making this tread is looking for help. so thank. </TD></TR></TABLE>
I wasn't trying to be an ***, but in your first post you said;
So you asked us to go to team-integra to check, and i was asking why you weren't able to go there yourself if your here asking about it and already know where to find the codes.
And i agree with JasonSt check for voltage.
Ali
Ali
cause im not familiar with team-integra, i just know that they have a link that go through with all the code, i just thought i need account to log in and seach.
Longitudinal
Jul 14, 2011 04:34 AM
