b18 swap question
Old Aug 26, 2006 | 08:01 PM
racingcrx's Avatar
Default b18 swap question
ok i have a b16 tranny i bought a while ago i swapped it in with the b18 and the speedo cable is attached to the tranny and i can't pull it off. i was thinking unplugging the speedo cable from behind the guage cluster. how hard is it to pull it out? do i have to take the dash out? THANK YOU VERY MUCH HONDA-TECH
Old Aug 26, 2006 | 08:26 PM
crxnj's Avatar
Default Re: b18 swap question (racingcrx)
its simple,,no you dont have to take the whole dash out...all you need to do this is a phillips screwdriver...Remove the cluster hood,,then you'll see the speedo cable in the back on the far right of the cluster (you cant miss it) its held in with a clip ,so just push the clip and pull and it comes right out.
oh dont forget to unplug anything electrical on the cluster hood,so you dont rip it when you take it off...
Dazer 1991
Jul 19, 2012 09:38 AM
evokiller666
Jan 27, 2009 11:47 AM
Civicracer17
Mar 13, 2006 04:49 PM
crxtreme27
Jan 19, 2005 05:48 PM
cutt
Nov 12, 2004 06:57 PM
