FS: P08, P2P, B16a header and downpipe, ETC...
Old Aug 26, 2006 | 03:21 PM
slowcivic2k's Avatar
Default FS: P08, P2P, B16a header and downpipe, ETC...
For Sale:
JDM P08 VTEC ECU 5 Speed
Part #: 37820-P08-900
Serial: 461-141429
Revision: ARJ
Manufactured by denshigiken.
ECU is in good condition. Was originally purchaced for a friends all motor D16Z6 project, but he decided to wreck his car, and refused to by it from me, I tested it on my D16Y8 civic, and also tested it on my B16A civic, and it works fine.
$90 OBO
US P2P OBD2b VTEC ECU 5-Speed
Part #: 37820-P2P-A12
Serial: 1213-248798
Revision: 6D
Manufactured by IPT.
ECU is in near mint condition, Came with my stock 2000 EX 5-Speed Coupe. Used for 95,000 miles, and then pulled it out for a B16A SiR-II motor, and P30 ECU, Item is in near perfect condition, and works just as well.
$80 OBO
1995 Civic SiR-II headers.
They were pulled off my motor to be replaced by an aftermarket tubular header, there are in great shape, a few scrapes on the downpipe, but no dents, comes with front and back heat sheid as well.
$45 OBO
P08-1 VTEC head.
I dont know what car this head came out of, but I did some looking and I've narrowed it to the US D16Z6, or the JDM D15B VTEC in Japan. The head casting is P08-1, comes with the camshaft, cam gear. VTEC solenoid was sold, as was the valve cover. Head is in good shape.
$35
Civic EX 2000 Power steering pump.
Great condition pump, was pulled when the motor was switched, has about 95,000 miles on it, works perfect.
$30 OBO
Civic SiR 1995 Power steering pump
Motor came with this pump that I cannot use due to the inlet size, Had to buy a GSR pump and everything was gravy. Pump has around 34,000 miles on it. Was ghetto rigged to the motor to see if it worked, and it works just fine.
$30 OBO
Civic SiR-II A/C pump.
Also came with my swap, but does not work in my car due to the outlets, has to use P54 bracket from a Del Slow and the stock pump. This pump is in great shape, turns great, but never tested, it has fresh oil in it, and it should work no problem.
$40 OBO
S20 Transmission from 1995 Civic
This tranny replaced the S40, which had bad bearings and needed to be rebuilt, which I will do later, This S20 was the replacement it has very similar gearing but not sure on the exact gear ratios, get with me about it and ill find them. Tranny is in excellent shape, ISB is good and tight, and there are no bad gears, mostly highway miles on this one, was used for about 5,000 miles after I got it, then pulled out for a B16A swap.
$200 OBO
If you have any misc need with stuff like this, ask, I have a lot of stuff floating around for sale, Even my car, check my sig link for more info, I need to have a CRX, I miss it so......
Old Aug 27, 2006 | 09:22 AM
Default Re: FS: P08, P2P, B16a header and downpipe, ETC... (slowcivic2k)
wake up bump
Old Aug 28, 2006 | 05:26 AM
bump...
maxwellmercer
Sep 9, 2010 07:00 AM
numberone
Jul 19, 2009 09:24 PM
JuicedSucka
15
Oct 4, 2005 05:40 AM
eg6ajk
Dec 15, 2002 04:13 AM
