H22a block posting
Old Aug 26, 2006 | 02:40 PM
mr_carman007's Avatar
Default H22a block posting
How well does this work for the h22 engines, and how much boost would you want to run if you have stock internals?
Old Aug 26, 2006 | 02:44 PM
TopEndUSA's Avatar
Default Re: H22a block posting (mr_carman007)
No more than 10psi for longevity.
Old Aug 26, 2006 | 03:44 PM
prelittlelude's Avatar
i don't know y you said h22a block posting because the h22a is a closed deck design so there is no way to block post a h22a
the h22s can handle quite a bit. but stock pistons can't no more than 9-10 on stock pistons on a GOOD tune
Old Aug 27, 2006 | 07:36 AM
DfwBB6's Avatar
Default Re: H22a block posting (MardreRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MardreRacing &raquo;</TD></TR><TR><TD CLASS="quote">No more than 10psi for longevity.</TD></TR></TABLE>
true with a good tune too
Old Aug 27, 2006 | 08:13 AM
Default Re: H22a block posting (Lude_Nation)
What if new pistons, rods, etc were installed how much boost could the motor hold?
Old Aug 27, 2006 | 12:44 PM
Honda Sport's Avatar
Default Re: H22a block posting (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">i don't know y you said h22a block posting because the h22a is a closed deck design so there is no way to block post a h22a
the h22s can handle quite a bit. but stock pistons can't no more than 9-10 on stock pistons on a GOOD tune</TD></TR></TABLE>
not for an h22a specifically but you get the point:
http://www.muller.net/sonny/crx/engine/posted.html
depends on which h22a he's asking about. obd1 h22a's are closed, obd2 ie:h22a4's are open.
true about the h22a's being able to handle boost. there's a few guys with 400whp+ h22a's on stock internals. not sure if they're daily drivin though. just make sure you have a good tune and don't go boost crazy.
msdh22
Aug 23, 2010 10:46 PM
ED9man
12
Jul 10, 2008 10:50 AM
killingtwobirds
Apr 18, 2007 10:44 PM
scUba-stEve
Jan 6, 2006 09:23 AM
prelittlelude
Oct 6, 2003 07:03 PM
