Timing belt/water pump change - how much coolant is needed?
Old Aug 26, 2006 | 11:29 AM
erikiksaz1's Avatar
Default Timing belt/water pump change - how much coolant is needed?
When you remove the water pump, how much of the coolant makes its way out? Would I need to buy a whole new container of it?
Old Aug 26, 2006 | 11:52 AM
vtec.dc2's Avatar
Default Re: Timing belt/water pump change - how much coolant is needed? (erikiksaz1)
i normally just buy 2, fill it up completely, fill overflow tank halfway inbetween low/high, then keep adding (after its been running/cool down) to overflow tank until its settled in between low/high again.
Old Aug 26, 2006 | 01:43 PM
erikiksaz1's Avatar
Default Re: Timing belt/water pump change - how much coolant is needed? (vtec.dc2)
Ok, so that's for a coolant flush. But what about when you're doing a timing belt change, does all the coolant make its way out of the water pump?
Old Aug 26, 2006 | 03:35 PM
RagingAngel's Avatar
The practice normally is to drain the coolant completely before changing the water pump.
Are you trying to avoid doing this because your coolant is relatively new?
The coolant does not bleed all the way out, since the pump is at the top of the block - you can probably get away with just topping it off with some distilled water depending on your location (does it freeze where you are?)
Old Aug 26, 2006 | 04:43 PM
erikiksaz1's Avatar
Default Re: (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
The coolant does not bleed all the way out, since the pump is at the top of the block - you can probably get away with just topping it off with some distilled water depending on your location (does it freeze where you are?)</TD></TR></TABLE>
You knew what I was thinking without me even mentioning it. Thanks
Old Aug 26, 2006 | 05:44 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (erikiksaz1)
you're good with 1 gallon
Old Aug 27, 2006 | 07:45 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (Evs-One)
1-1.5 max
**** bleeding the system is easy, just run it till hot wait for upper and lower hoses to heat up and then just open the bleeder screw.
hondas are easy compared to cavaliers, those you literally have to force a vacuum in the system to bleed.
justint7121
Nov 21, 2010 09:46 PM
dleccord
Jan 11, 2010 06:59 PM
wedtm
Mar 26, 2008 07:59 PM
Lude-Lee
Feb 18, 2008 07:50 PM
phanatic
Jul 9, 2006 07:47 PM
