FS: CRX EF8 - P72 ECU - D and B Series Axles - D16 Alternator - 88 and 89 SI Door Panels - SI Gauge
All prices are Or Best Offer, I want this **** gone now. None of the prices include S/H.
FYI: The "CRX EF8" in the title is for search purposes, you will not find a EF8 for sale here.
Virgin JDM P72 5spd ECU OBD2b from a 2000 Integra
$80
<u>D-Series Axles</u>
A set of axles taken from my 88 CRX SI when I did my B swap. No tares in the boot, these are both good to go!
$50 a piece, $90 for Both
<u>B-Series Axles </u>
This is a set of brand new, in the box B Series axles for 90-93 Integra WITHOUT ABS. One is from Autozone, the other from Advanced Auto, both have lifetime replacement warrannties, of which I have recipts for, and neither have ever been used.
$95 each, no breaks
<u>D16 Alternator</u>
Exactly as stated, pulled from a 1990 Civic SI, in perfect working condition
<u>88 CRX SI Door Panels </u>
These are from a 1988 CRX SI so no ugly doormounted seatbelts here! The Driverside is rather worn on the top, and there's alot of wear on the lower rear, bnut the over all door panel is very clean (all of this is pictured) The Passengerside however is rather clean, with no major blemishes.
The only problem is they have had holes cut for tweeters, which might not even be a problem to you!
$60 FIRM
<u>89-91 SI Door Panels</u> - These are also in OK condition, as you can see the CRX has been painted Yellow by some *******.......and there are Tweeters mounted on the doorpanels that are included. Other then that their OK, with 1 hole punched in the door panel from the seat belt on the DS, and a puncture on the PS (both pictured). I'd say these are 7/10. $40 FIRM plus SH
<u>88-89 SI Gauge Cluster w/White Faces and Indiglo</u> - Exactly as says, the tach face has a little smudge on the actual gauge (inside the plastic) but other then that these are good to go. The switch in between Green and Blue, not that it matters but there's 266K on the Odometer. Make me an Offer.
<u>Door Handle Set #1</u> - These are from an 88 SI and the handle's are fine, the stickers are a little torn a bit, you should be able to get an idea. $10 Plus SH
<u>Door Handle Set #2 </u>- I dont know what these came out of, but their like grey, but not the same as the grey SI ones above. Not blue....IDK? The stickers on these are a bit better than the others, $10 plus SH
<u>Passengerside Mirror</u> - This is from an 89 DX, the mirror is fine and there's no major scratches on the otherside as can be seen, only minor scuffs. $10 + SH
<u>Random Interior Parts</u> - These are all black/grey, $3 a part plus SH
<u>1988 CRX SI Headlights w/ Mounting Brackets </u> Make offer
<u>88 CRX Bumper Lenses </u> - One is cracked, $5
88 SI Windows - Their windows, you know what they look like, so no pics. They have no chips or scratches. $20 plus SH
If you need vouches, I don't keep a vouch thread, but I've done business with numerous people on here and can cite vouches per request.
PLEASE BUY MY STUFF!
$80
$95 each, no breaks
$60 FIRM
Bump for you Ross.
Is there any condensation or cracks in those headlights?>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doitdub »</TD></TR><TR><TD CLASS="quote">Bump for you Ross.
Is there any condensation or cracks in those headlights?></TD></TR></TABLE>
my bad buddy I forgot about this thread!
