Cooling problem
Old Aug 26, 2006 | 05:41 AM
rcar97's Avatar
Default Cooling problem
My fan won't come on when hot, tested fine straight from the battery, upper and lower rad hoses are hot. The upper is expanding as it gets hotter. Is the switch or thermostat to blame? If I short the connector on the switch will the fan work?
Thanks
Old Aug 26, 2006 | 02:15 PM
YellowKahuna's Avatar
Default Re: Cooling problem (rcar97)
Check your fuse box 1st
john79
May 25, 2018 05:04 AM
david420
Sep 20, 2012 04:42 AM
manny81
Apr 22, 2007 12:23 PM
kai-chun
12
Sep 8, 2006 03:20 PM
gobblebox59
Aug 29, 2004 02:04 PM
