JDM ZC ECU ..i need ecu map with wiring explanation ASAP!!
Old Apr 26, 2002 | 07:47 PM
JinMTVT's Avatar
New User
Default JDM ZC ECU ..i need ecu map with wiring explanation ASAP!!
hi!
doing a ZC to DX automatic ( going to MT ) swap ..
so i need to know what does what on the ZC ecu
please if anyone knows a link to a full ecu description with pictures of wire numbers and what they do
thanks
Old Apr 26, 2002 | 08:01 PM
VTECVillain's Avatar
Default Re: JDM ZC ECU ..i need ecu map with wiring explanation ASAP!! (JinMTVT)
You're gonna need to switch from the Dual point injection to MPFI along with the auto to manual swap. Here's a link to the wiring differences between the DX and ZC - http://www.hasport.com/dx_zc.htm which should help you out.
Old Apr 26, 2002 | 08:14 PM
JinMTVT's Avatar
New User
Default Re: JDM ZC ECU ..i need ecu map with wiring explanation ASAP!! (VTECVillain)
are all the plugs on the ecu like that :
A 1 3 5 ... B 1 3 5 ... C 1 3 5..
A 2 4 6 ... B 2 4 6 ... C 2 4 6 ..
Old Apr 26, 2002 | 08:32 PM
Yes, that is how HASport has the pinouts numbered on their site. If you were to pick up a Helms manual for your car, it would be numbered straight across instead of up and down. Then if you get a 92+ the Helms are numbered up and down. I don't know the reason certain companies switch them and all that. It can get confusing and you could end up with the wrong pinout if you're not using the same system.
Old Apr 26, 2002 | 08:39 PM
JinMTVT's Avatar
New User
well on the ecu plugs ( the b and c )
they are noted on straight line instead of alternate ..
so i was wondering cause i knew that the injector pins were at 1234 on the plug label
eheh
ok thanks neway..i'll work with all that..
Phils
Jun 5, 2007 03:43 PM
funkyfreshpnoy
Mar 12, 2006 05:12 AM
ek_99_SiR
Feb 21, 2004 02:23 PM
tdc
Feb 23, 2002 08:32 AM
