TPS Wire Color?
Old Aug 25, 2006 | 07:44 PM
HickamHatch's Avatar
Default TPS Wire Color?
Did a search and need to know which wires are TPS wires, have a 96 LS..
thanks
Old Aug 26, 2006 | 01:34 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: TPS Wire Color? (93civic96ls)
what are you trying to do? the tps is pretty easy to locate on the throttle body.... or do you mean the wires so you can find them in harness?
Old Aug 26, 2006 | 01:11 PM
Default Re: TPS Wire Color? (God.Loves.Ugly)
the color of the wires to the plug
Old Aug 26, 2006 | 05:32 PM
D.Dappa's Avatar
tps wires? the tps wires are located on the clip that connects to the sensor you have use a volt meter and test more than one if i remember supposed to read a certain voltage at idle and then a different at full trottle get a helms or haynes manual it will tell you the exact procedure....
Old Aug 26, 2006 | 08:21 PM
i just need to know so i dont mix up my tps and map wires
brakedrum
Oct 16, 2010 08:57 PM
TwoKSiR
Jun 13, 2008 07:20 PM
djgruesome
Jul 3, 2006 01:37 AM
drjondurst
21
Apr 9, 2003 08:37 PM
