B20 Vtec turbo info needed!
Old Apr 26, 2002 | 07:06 PM
E Swift's Avatar
Default B20 Vtec turbo info needed!
I am going to make this simple. I want to experiment with the B20 Vtec swap. But, I want to learn a little bit more about it first before jumping into it. So, give me some info on it. Recommendations? I'm throwing it into my 94 LS integra. I've already got a GSR tranny with LSD, so I'm already set on that. I just want info on the motor now. What can I safely boost on it? Better to have the B16A or B18C5 head on it? Why?
Help!
Old Apr 26, 2002 | 07:48 PM
Kamin's Avatar
Default Re: B20 Vtec turbo info needed! (EricJ)
the b16 heads flow better than the GSR head.
and for boost, i would have the block resleeved. im not sure how much boost it will take stock but i KNOW its more than any other b series motor. http://www.crvtec.com
learn from there
Old Apr 26, 2002 | 10:43 PM
Slain's Avatar
Default Re: B20 Vtec turbo info needed! (KAMiN)
heheh doing some research on the b20 like we talked about the other night.. if everything is perfect your car would be a sic puppy on the streets keep searching brotha
Old Apr 27, 2002 | 06:07 PM
E Swift's Avatar
Default Re: B20 Vtec turbo info needed! (Slain)
I wanna break 12's. I know its going to be tough, but, its a project that I've been meaning to finish.
Old May 4, 2002 | 06:08 PM
Turbo Laser's Avatar
It's practically the same as the B18, but with larger bores.
Kannan08
Feb 3, 2012 01:35 PM
steveDC2
Jan 24, 2010 04:17 PM
mysterysktr7
Apr 23, 2009 07:51 PM
viet1337
Apr 10, 2007 09:51 PM
bonestock92si
Aug 20, 2004 06:42 AM
