d16y8 in 88HF CRX no vtec wanted
Old Aug 25, 2006 | 06:30 PM
6doorsentra's Avatar
Default d16y8 in 88HF CRX no vtec wanted
im going to put this motor in my 88hf. I dont have any harnesses or anything to run vtec. I dont want to run it. I just want the 99 motor to run in the car. I have no dist on the d16y8. I have everything else-complete. What do I need Differently not stock on the HF to make the motor run?
Please help-this will be done tommorow morning
Old Aug 25, 2006 | 06:39 PM
godruler's Avatar
Default Re: d16y8 in 88HF CRX no vtec wanted (6doorsentra)
that should be pretty easy, if you really wanna keep it simple, your hf dizzy, and manifolds should bolt up to the y8 head, and run your harness and ecu and everything, cable tranny mounts right up, can't use the y8 flywheel though because your '88 uses a smaller clutch which uses a smaller pressure plate bolt pattern, bolt your '88 flywheel and clutch assembly onto the y8 if your using your stock '88 hf tranny, use your axles, hubs, etc.. you'll probrably have to relocate your temp sensor and someother small things but it should run, i have an obd1 motor (not vtec) in my car with obd0 stuff bolted on and it runs fine
Old Aug 25, 2006 | 06:41 PM
godruler's Avatar
Default Re: d16y8 in 88HF CRX no vtec wanted (godruler)
i'd recommed eventually getting at least all obd0 SI stuff to run the car and an SI tranny for an awsome dirt cheap way to wake up that super light rex
Old Aug 25, 2006 | 06:56 PM
1990si's Avatar
if you dont run vtec its gonna be running on low cam all the time and be slow as ****. convert to obd1 and get a vtec edu or at least get a vtec controller
Old Aug 25, 2006 | 11:40 PM
i dont want vtec. so put manifold and dist on motor from hf? then wire it up?
Old Aug 26, 2006 | 01:48 AM
davens's Avatar
Default Re: (6doorsentra)
GHET-to engineering at its finest.
Your tranny and exhaust manifold will bolt to the D16y8. I'm not sure about the intake manifold. Worse case scenario, you do a y8 manifold hack job.
Your HF distributor will bolt to the y8 head. Use as much of your old HF wiring as possible.
Bad ideas
1. The HF ecu (fuel/timing maps) is meant for running a smaller, leaner engine. Too lean a mixture can blow an engine quick. Especially in Houston summer heat.
2. No vtec. While the y8 low cam is punchy at low rpms, it peaks early and power delivery drops off dramatically at 4500rpms. Which may be what to you're used to in an HF, but its like putting a v-8 in a car and leaving the spark plug wires disconnected from two cylinders.
3. You'll probably have emissions issues. Even if you reconnect all the emissions equipment, the tune is going to be too far out of whack to be adequately corrected.
Old Aug 26, 2006 | 04:05 AM
7PSI CRX's Avatar
Default Re: (davens)
You WILL NEED the wiring plug & lead wires for the temperature sensor that is now located on the thermostat housing.
You can not use your old radiator fan switch sensor, and the new plug is different.
Old Aug 26, 2006 | 08:37 AM
I can't get the vtec harness, ecu, jumper cable to wire up vtec. i need the vehicle to run. Which harness can I get right now that will help out this swap easier? Get a vtec harness from a 92-95 civic?
Old Aug 26, 2006 | 09:09 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">I can't get the vtec harness, ecu, jumper cable to wire up vtec. i need the vehicle to run. Which harness can I get right now that will help out this swap easier? Get a vtec harness from a 92-95 civic?</TD></TR></TABLE>
Use the stock crx hf wire harness you got..like people said just use everything from the old motor ,,dizzy,manifolds,tranny,mounts,etc...IMO you should atleast get a pm6 ecu though..cause atleast its 1.6 and you can always chip it for vtec later on.
Old Aug 26, 2006 | 09:57 AM
Since i'm going to get an obd1 dist... which wire harness do i get to wire it up?
NOFX
27
Nov 6, 2011 03:43 PM
lxiaccord
Apr 20, 2009 12:12 PM
pfiaccord
Aug 2, 2005 08:36 PM
1990hf
Jul 12, 2004 05:28 PM
Davanca
Aug 12, 2003 05:45 AM
