what ecu and what o2 sensor do i use?? jdm d15b
Old Aug 25, 2006 | 03:49 PM
ph0shizzle's Avatar
Default what ecu and what o2 sensor do i use?? jdm d15b
alright well i have a jdm d15b swap in my ek. currently i have a chippd p28 and a 4wire o2 sensor and have no CEL. i did some research and found out im supposd to use the p08 ecu and a 1wire o2 sensor? is this true? if so, where can i buy the ecu at?
Old Aug 26, 2006 | 02:58 AM
BlueIntegraBoy's Avatar
Default Re: what ecu and what o2 sensor do i use?? jdm d15b (ph0shizzle)
Well, if you are using a chipped P28 with the P08 basemap and 4-wire O2 sensor, you should be fine. The P28 looks for the 4-wire while the P08 looks for the 1-wire.
You might be able to find the P08 on eBay and you will need to use a 92-95 Civic CX O2 sensor. But like I said, why change anything when your car is already running fine.
Old Aug 26, 2006 | 12:39 PM
ph0shizzle's Avatar
Default Re: what ecu and what o2 sensor do i use?? jdm d15b (BlueIntegraBoy)
because i heard u could only hit the 3stagevtec if u run the p08. idont know if thats tru but i remember readin it somewhere on someones thread.
Old Aug 26, 2006 | 02:26 PM
NJcoupe's Avatar
Only certain D15b's came with the three stage vtec.
Old Aug 26, 2006 | 02:49 PM
schardbody's Avatar
if you are running the 3stage vtec (w/ 2 vtec solenoids) neither ecu is correct, and you wont go into lean burn, but will have vtec. the 3stage vtec is OBD2 and uses an OBD2 ecu (have fun finding that). if you have no codes leave it alone.
shredderkid322
12
May 8, 2012 06:10 PM
shredderkid322
Mar 31, 2011 01:40 PM
birdtc1
Feb 24, 2010 10:13 AM
variable
Engine Management and Tuning
Oct 16, 2009 01:59 PM
ph0shizzle
Jul 24, 2006 12:44 PM
