p28 or p72 chipped?..
which of the two chipped ecu's will be beneficial in a mild all motor setup. so far my setup consist i/h/e, and chipped p28, was a chipped p72 before, but ran like shi*t. parts on the way are bc3+ cams, aem cam gears, ti retainers and valve springs, blox intake manifold, edelbrock tb, fuel system upgrades later on, and a stock block for now. What performance gains or efficiency should i expect with the p28 over the p72 i had before.
Honestly....if you have an obd1 p72, I'd keep it stock because its actually worth more as a virgin ecu than it is chipped suprisingly. Since p28's are more abundant, I'd run a chipped p28, especially if your swapping to a single stage manifold. It definately would be beneficial if you get it tuned for your set up.
I could be wrong, but if your going to run the ECU's chipped anyway, I think the only diff between the p72 and p28 is the p72 can open the secondary butterflies on the intake manifold, since your running a single stage, I'd go with the cheaper p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">Honestly....if you have an obd1 p72, I'd keep it stock because its actually worth more as a virgin ecu than it is chipped suprisingly. Since p28's are more abundant, I'd run a chipped p28, especially if your swapping to a single stage manifold. It definately would be beneficial if you get it tuned for your set up.</TD></TR></TABLE>
yah im, definitely getting a single stage mani, im deciding either on a blox or skunk2 IM, gonna have it put in next week.
Thanks for the info. Ill be using the single stage soon enough, plus to add to the performance ill be running some bc3+ soon hopefully
Modified by egg6vtak at 12:50 PM 8/25/2006
MOVE OVER
Sep 6, 2007 08:59 AM
ilovejdmhoes23
Jan 20, 2007 11:52 PM
u2civic1
Apr 1, 2003 09:54 AM
