93 LS swap into 90 HF
Hey guys, first off, I have to admit this being my first time on the CRX board, I'm always on the FI board b/c of my turbo teg, but I ran across a motor for my REX at a good price (free) so I need to know what all I need to complete the swap.. The donor car was a 93 LS, I have the complete car, it was wrecked, so the harness, axles and hubs are at my use.. Just from looking at it, I noticed that the engine plugs are different but the motor mounts are in identical places... PLEASE any info is appreciated as the heart transplant begins tmr!!
thanks
Aaron
96 turbo GSR 12.6 @ 117
90 CRX ...... under construction
thanks
Aaron
the Integra plugs are grey, but they are not like the one's on my 96 Teg.. If i have the complete harness, could I just swap it all over to the CRX? The motor mount kit, does that replace all three?? Isn't there a certain year LS motor that dropped right in? Lastly, will the teg axles fit on the CRX's hubs or how do i go about that part?? thanks for all the info guys..
Aaron
Aaron
unless you want to convert to obd1 you will also need a 90-91 LS ecu.just thought i would add that one.i think you have to swap hubs also but i am not sure because i think the HF hubs dont have enough splines.and about the certain year teg just dropping in i dont think there is one that will fit like that in a 4th gen.maybe?
[Modified by 89EF-BCUMBIE, 1:58 AM 4/27/2002]
Upgrade your brakes too
You'll probably warp those HF brakes on the first day lol. To answer your question before 88-91 B series swap you need a mount kit 92-whatever the year is I believe is a direct drop. Good luck.
Brandon, so you're saying that the 93 motor is going to be a direct drop in? Previous replies say that i'll be needing mounts.. can someone pls give a definite answer.. thanks again
Parts you're going to need for sure:
* B Series mount kit: HASport, HCP, Place Racing, Etc.
* HASport or HCP Shift linkage or shorten the one from the Integra to fit
* Knuckles and hubs from the Integra
* Replace the Integra motor harness with your HF harness
If you don't want to convert everything to OBDI (grey plugs) you'll also need:
* 90-91 Integra LS ECU
* 90-91 Integra LS Distributor
* 90-91 Integra LS or 88-91 Civic/CRX Si Fuel injectors
savageevo
Aug 18, 2005 02:01 PM
.Noah Fecks
Aug 23, 2003 12:54 AM
