ok time to change things up, EF mounts, LS swap, misc stuff
FS or trade, everything is still on car. so if you wanna see the engine running you can, listen to the exhaust, you can drive it too(though it has a f**cked up vibration in the susp)
****pending****1992 LS engine and trans/axles, 5k on dizzy, 12k on t-belt, water pump, clutch(exedy), flywheel (10#), plugs, and wires. no ex mani or wiring included. - $850
****pending****EF b-series cable mounts, 12k on them - $150
EF b-series linkage w/ b&m short shifter - $130
2.25" magna flow cat, 6k mi, direct bolt in for b-series into EF so you dont need to cut up your exhaust(may fit others, i'm not sure) - $120
el cheapo 4-2-1 2 piece header - $100
1991 PR4 ecu - $70
60mm stainless exhaust, 88-91 hatch. non rice, painted grey and tip cut off - $175
CRX Si front sway bar, no endlinks - $35
new LS timing belt - $30
EF poly trailing arm bushings - $20
i have a blown holset h1c(early dodge cummins turbo,HUGE) if anyone is interested, i cant remember where i put it but if someone is interesed i'll see if i can find it
any interior parts, except dash, door panels, and front seats. bluishgrey color, most are in great shape. just ask i prob have it, rear seats are vinyl.
most of my susp will be for sale once i figure out what is causing the vibration, dont wanna sell any bunk parts.
i am willing to trade for:
d16a6 or DOHC ZC complete swap,engine can be blown just no bent rods, scarred crank, or major ****.(eng, trans, axles, linkage w/shifter, mounts, dizzy, int mani/tb, all sensors)
EF traction bars
non-ebay BOV
450-650cc inj (sat or non-sat doesnt matter)
3" 88-91 hatch exhaust
d-series t3 mani (ext or int gate doesnt matter)
2.5" FMIC piping
94-newer b-series TB
LM-1 or LC-1 WBo2 setup
honda/T3 oil lines
i will be adding to the FS list and the want list in the near future, i will part out engine if need be. i will work deals on multiple items
i am located in Knoxville MD (across the potomac from harpers ferry)
Modified by RACINTWEEK at 8:10 AM 8/28/2006
1991 PR4 ecu - $70
EF traction bars
non-ebay BOV
2.5" FMIC piping
honda/T3 oil lines
i have 91 hatch could you email me pics of the 2 exhaust system you have to gmback23@aol.com.might be interested in one of them
N1Concepts
Northern California (Sales)
Jul 22, 2009 11:17 AM
