6th gen V6 spark plug
i found out that honda uses and recomends NGK double platniums for the V6. but those are about $14 each, but the NGK ix iridiums are only about $9 each. as far as im concerned iridium is a better metal for plugs and should perform better. has anyone noticed a diference in running the iridums vs the platnium plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">i found out that honda uses and recomends NGK double platniums for the V6. but those are about $14 each, but the NGK ix iridiums are only about $9 each. as far as im concerned iridium is a better metal for plugs and should perform better. has anyone noticed a diference in running the iridums vs the platnium plug?</TD></TR></TABLE>
from weird idle to less gas mileage? yeah~!
I am only using copper vpower on my accord, i am running some platinum ngk on my S, it's required for the f20c
50-60 bucks
50-60 bucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">
50-60 bucks
is your accord a L4 or V6? so has the weird idle and bad mileage been proven to be a problem with the iridium plugs? any reason why iridium would cause that?
50-60 bucks
</TD></TR></TABLE>is your accord a L4 or V6? so has the weird idle and bad mileage been proven to be a problem with the iridium plugs? any reason why iridium would cause that?
ykwak
Jul 20, 2006 06:03 AM
