2000 civic si tire pressure
Old Aug 24, 2006 | 08:57 PM
5spdHatch4Life's Avatar
Default 2000 civic si tire pressure
This may sound kinda stupid, but i was looking for someone who knows the factory reccomended tire pressure for a 2000 civic SI. 195/55-15 tires
Modified by 5spdHatch4Life at 10:29 PM 8/24/2006
Old Aug 24, 2006 | 08:59 PM
SmogKing's Avatar
Default Re: 2000 civic si tire pressure (5spdHatch4Life)
Read the outter wall of the tire. Every tire has different psi. specs.
Old Aug 24, 2006 | 09:19 PM
SOHC4life 96's Avatar
Default Re: 2000 civic si tire pressure (SmoGuy)
It's usually 35-40 psi
Old Aug 24, 2006 | 09:25 PM
Sr420Det's Avatar
Unless your drag racing
Old Aug 24, 2006 | 09:26 PM
Default Re: (switchintotheh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by switchintotheh22 &raquo;</TD></TR><TR><TD CLASS="quote">Unless your drag racing</TD></TR></TABLE>
Had he mentioned anything about drag racing, I would have added to my answer or changed it completely. But he didn't, so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">It's usually 35-40 psi</TD></TR></TABLE>
Old Aug 24, 2006 | 09:27 PM
EK k kay's Avatar
It's around 30psi front and rear. That's what I use in my 99 hatch. Do not inflate to the rating on the side of the tire.
Sr420Det's Avatar
know wonder i couldnt chave my avatar
Man thats skrewed up
Old Aug 24, 2006 | 09:30 PM
Sr420Det's Avatar
why wouldnt you fill to spec
gets better gas milage plus its safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">It's around 30psi front and rear. That's what I use in my 99 hatch. Do not inflate to the rating on the side of the tire.</TD></TR></TABLE>
Some of the time it's right, others not really. When you have stock wheels and OEM tires, the correct PSI is in one of the door jams.
Old Aug 24, 2006 | 09:34 PM
Sr420Det's Avatar
Default Re: (EK k kay)
Originally Posted by switchintotheh22
Unless your drag racing</TD></TR></TABLE>e tire.
Why r u so mad?
Old Aug 24, 2006 | 09:35 PM
bokals's Avatar
for my tires its 44 psi
Old Aug 24, 2006 | 09:50 PM
yoej8's Avatar
Factory recommended tire pressure for the stock tires are 30 front and 29 rear. you can find it on the sticker by the driver side door
16v
Mar 21, 2008 08:49 PM
kaluwa3
Sep 20, 2007 10:11 PM
cecknight
Jul 19, 2007 07:10 AM
BDogggUT34
Nov 28, 2005 10:39 AM
2k1 GSR
Dec 14, 2003 11:50 AM
