AC only comes on when it wants?? 95 Civic.
Old Aug 24, 2006 | 07:17 PM
RyanA's Avatar
Default AC only comes on when it wants?? 95 Civic.
I'm wondering if something is wrong with the actual climate controls. AC pressure is there. Compressor and condensor fan does not even attempt to come on sometimes. Seems like there is a loose connection somewhere. When AC comes on, it is very cold. Low side pressure is right where it needs to be when the compressor does cycle.
Any ideas? Is there a cold solder joint problem on Civics like there is on the Preludes??
Ryan
Old Aug 24, 2006 | 07:25 PM
saikouEF8's Avatar
Default Re: AC only comes on when it wants?? 95 Civic. (RyanA)
yes very possible... will probably get worse over time also... even longer times to kick in in winter wen u have to use it to do that cold defrosting thing.. do u get me?
Old Aug 24, 2006 | 07:50 PM
Striker_1818's Avatar
Default Re: AC only comes on when it wants?? 95 Civic. (saikouEF8)
loosen plug
and wouldn't hurt checking your fuse
Old Aug 24, 2006 | 09:09 PM
95_rhd_civic_coupe's Avatar
Default Re: AC only comes on when it wants?? 95 Civic. (Striker_1818)
mine was doing same but i removed all ac~~~
Old Aug 24, 2006 | 09:11 PM
Default Re: AC only comes on when it wants?? 95 Civic. (95_rhd_civic_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_rhd_civic_coupe &raquo;</TD></TR><TR><TD CLASS="quote">mine was doing same but i removed all ac~~~</TD></TR></TABLE>
that won't help him lol
Old Aug 26, 2006 | 02:43 PM
RyanA's Avatar
Fuse is fine. AC light comes on on my climate control but the compressor and condensor fan only turn on sometimes. When you say loosen the plug, what do you mean??? Do the solder joints need to be re flowed like on the Prelude climate controls???
Ryan
Old Aug 27, 2006 | 07:51 AM
Probably since it's common for joints to loosen due to normal wear...
or maybe a loosen wire which isnt making contact
lakerschamp2000
19
Apr 24, 2009 12:37 PM
crxsi8
Aug 22, 2005 05:41 PM
tub_sephiroth
Jun 27, 2005 11:13 AM
vietnogi
May 24, 2005 08:01 AM
Sinner
May 1, 2005 07:19 PM
