hyper ground wires install
Old Aug 24, 2006 | 06:24 PM
hatch96y7's Avatar
Default hyper ground wires install
can anyone help me on some how to to install these on my engine i have no clue and cant find nothing on the search
Old Aug 24, 2006 | 07:26 PM
BlueIntegraBoy's Avatar
Default Re: hyper ground wires install (hatch96y7)
Just ground a wire to various parts of the engine (ie valvecover, transmission, starter, etc.).
Old Aug 25, 2006 | 03:46 PM
hatch96y7's Avatar
Default Re: hyper ground wires install (BlueIntegraBoy)
do u have a more detailed description possibly some pictures thanks
Old Aug 31, 2006 | 03:23 PM
hatch96y7's Avatar
bump
Old Sep 1, 2006 | 01:20 AM
JayDuM1's Avatar
you can bolt them n e where in the bay like the stock ones
Old Sep 1, 2006 | 03:10 AM
Jimmy's Avatar
Global Moderator
If you don't know what a ground wire is or where they are located i don't suggest you go to replace them by yourself.
Old Sep 1, 2006 | 03:37 PM
hatch96y7's Avatar
Default Re: (Jimmy)
if u dont have an answer dont post thanks
Old Sep 2, 2006 | 10:02 AM
hatch96y7's Avatar
Default Re: (hatch96y7)
bump
Old Sep 2, 2006 | 11:26 AM
hatch96y7's Avatar
bump
Old Sep 2, 2006 | 11:32 AM
EeeJayEight's Avatar
they replace the stock grounds as mentioned before
-valve cover
-tranny
-etc
search is your friend
https://honda-tech.com/zerothread?id=948402
Old Sep 3, 2006 | 01:24 PM
hatch96y7's Avatar
Default Re: (EeeJayEight)
bump
Old Sep 3, 2006 | 02:20 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">if u dont have an answer dont post thanks </TD></TR></TABLE>
If you don't have any ******* knowledge don't make a TOPIC.
It's ground wires?? Come on now
You need a 10mm Socket and a ratchet & go out and find your ground wires.. One on the tranny, one on the valve cover, etc.
Ok.. Thanks
your welcome.
Old Sep 3, 2006 | 03:15 PM
why did you bump again?
like 4 people gave you answers on what to do?
also if you dont like that info
go to search
change it to "archived"
select "92-00 civic"
and then type "ground wires"
and you will return a lot a results
Old Sep 3, 2006 | 04:39 PM
hapexamendios 2.0's Avatar
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">if u dont have an answer dont post thanks </TD></TR></TABLE>your an idiot, people told you exactly what and where and you want pictures?! you replace the ones THAT ARE ALREADY THERE!
Old Sep 3, 2006 | 05:58 PM
hatch96y7's Avatar
Default Re: (honda 3300)
thats y i make a topic because io dont know what to do *** and the way that people are describing this isnt the same as my wires i have like a cap that all the wires connect to so y u even respond if u just get urself mad
bump and does any one have a 99 front end conversion for a 96 ek
Old Sep 3, 2006 | 06:07 PM
hondaj05's Avatar
are you talkin about GROUND wires..... or SPARK PLUG WIRES? or do you have the two confused? if im thinkin right, the ground wires you bought are flat and braided.....right? those are ground wires, and those will replace the wire running from your trans among other things, and the most obvious one is on the valve cover-thats the thing that says HONDA on your engine...with the spark plug wires coming out of it......that brings me to this....those 4 wires coming from the top of you engine, those are spark plug wires.....if your trying to replace those with a ground wire kit.......please leave. thanks.....and if you can't tell the diff between the two of these, a front end conversion is WAY out of you league....simple enough for you? and btw, if you bump after this infantile explanation to your question, i will e-slap you! later,
Old Sep 3, 2006 | 06:23 PM
sohctodohc's Avatar
Default Re: (hondaj05)
bahahahah he means the dis. cap and spark plug wires not ground wires. wow man leave your car stock dont touch nething if you dont know the diff between ground wires and spark plug wires.
Old Sep 3, 2006 | 07:44 PM
Sketch_hs's Avatar
how about you stop doing ricer bullshit that adds nothing more than extra weight and wires
do some real mods (swap, turbo...) or go home...
Old Sep 3, 2006 | 07:49 PM
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">thats y i make a topic because io dont know what to do *** and the way that people are describing this isnt the same as my wires i have like a cap that all the wires connect to so y u even respond if u just get urself mad
bump and does any one have a 99 front end conversion for a 96 ek</TD></TR></TABLE>even with spark plug wires, its common sense type of ****
Old Sep 3, 2006 | 08:03 PM
matt56's Avatar
Wow why are all of you flaming him?? he needs detailed info and if you cant give it then why call names? the reason he asks is because the ground wire kit comes with like five or six ground wires and a braket thing thay all connect to and he needs to know exactly where to hook them up. oh and btw iv seen dozens of dyno charts after these are hooked up and hp gains range from 5 hp to almost 20 beleave it or not, and gas milege goes up alot too not to mention everything electical on the car works a whole lot better. but sorry hatch96y7 im not sure how thay all hook up, but im buying some within the next month so if i figure it out and you havnt yet then ill let you know how thay hook up
Old Sep 3, 2006 | 08:20 PM
hatch96y7's Avatar
Default Re: (matt56)
thanks matt 56 that is exactly what i was talking all these stupid *** ht freaks dont know the diffrece between SPARK PLUG WIRES and GROUND WIRES i know how to look at my engine and realize the diffrence between the both and some of thses idiots think that swapping something is the only way to gain horsepower but thanks any ways and if u do happen to figure out how to set these up please let me know
Old Sep 3, 2006 | 08:31 PM
PinkMaggit's Avatar
the circle goes bolted to the passenger side shock tower. The little one to the battery. Find the right size one that hooks up where your stock tranny ground hooks to. Long one to valvecover. Connect one more to the block - anyplace really. The rest you dont need just hook it up wherever you want.
If there are two linked like this O------o----o One goes by the rad and the other one to the motor etc..
best possible help your probably going to get man.
Good luck!
Old Sep 3, 2006 | 08:35 PM
hatch96y7's Avatar
Default Re: (PinkMaggit)
thanks that helps so the cap where all the wire meets bolts to the shock tower like where u bolt a strut bar
Old Sep 3, 2006 | 08:59 PM
PinkMaggit's Avatar
ya usually it fits right over it. you should be able to see it just try and place it over it.
Old Sep 4, 2006 | 12:32 AM
sohctodohc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt56 &raquo;</TD></TR><TR><TD CLASS="quote">Wow why are all of you flaming him?? he needs detailed info and if you cant give it then why call names? the reason he asks is because the ground wire kit comes with like five or six ground wires and a braket thing thay all connect to and he needs to know exactly where to hook them up. oh and btw iv seen dozens of dyno charts after these are hooked up and hp gains range from 5 hp to almost 20 beleave it or not, and gas milege goes up alot too not to mention everything electical on the car works a whole lot better. but sorry hatch96y7 im not sure how thay all hook up, but im buying some within the next month so if i figure it out and you havnt yet then ill let you know how thay hook up </TD></TR></TABLE>
5-20 hp??i never knew brighter headlights and .000001 better mpg gave that much horsepower haha post dyno graph until then quit passing out misinformation
