transmission changeover, now no electrical
Old Aug 24, 2006 | 03:58 PM
shutta's Avatar
Default transmission changeover, now no electrical
I swapped transmissions, and I had stereo running lights worked, horn etc, and now I get everything wrapped up finally and go to crank it over and it clicks, and then I lose all electrical. no horn nothing. i figure battery is dead, hook up the jumpers to my jeep, still nothing, I can't find any fuses blown anywhere. what ones shoudl I double check and what coudl be causing this problem?
Old Aug 24, 2006 | 07:12 PM
tacticalcustoms's Avatar
Default Re: transmission changeover, now no electrical (shutta)
grounds.. recheck all your ground wires... I had the same issue.
Old Aug 24, 2006 | 07:13 PM
mgags7's Avatar
most likely you forgot the ground wire that goes from the battery negative to the radiator support and also to the transmission
dwashy21
Nov 15, 2013 04:16 PM
t3h jam
Mar 10, 2010 10:45 PM
wicked_b16eg
Jan 6, 2008 11:13 AM
hb_guy
Apr 9, 2006 06:43 PM
Full Race A6
Audio / Security / Video
Jan 30, 2004 08:38 AM
