Where is the fog light relay located on a 93 civic ex coupe?
lower right in photo... everything should be all in one harness, but maybe yours is cut... it attaches to a hole just above the steering column.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">
lower right in photo... everything should be all in one harness, but maybe yours is cut... it attaches to a hole just above the steering column. </TD></TR></TABLE>
I found it......my blue/red wire with the brown connnector is broken. I cannot find where that bastard exits the car to the outside.
For what I can tell the wire that is broken is a hot wire and should be able to run it to a 12 volt source...
Suggestions?????????
Thanks guys.
Thanks guys.
The blue/red wire is the wire connecting the two harnesses. It's hot when the switch is turned on.
What's your problem? Fogs not turning on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">The blue/red wire is the wire connecting the two harnesses. It's hot when the switch is turned on.
What's your problem? Fogs not turning on?</TD></TR></TABLE>
Well when I did my RHD swap I must have tucked em or........
I just can't find the wires outside the firewall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">
I just can't find the wires outside the firewall.</TD></TR></TABLE>
find where it goes from the fog lights to the driver side where it connects to the ground behind the window washer thingy.. there is a negative ground spot there and then a connector there which should lead to the wire going from there to the firewall then inside.
find where it goes from the fog lights to the driver side where it connects to the ground behind the window washer thingy.. there is a negative ground spot there and then a connector there which should lead to the wire going from there to the firewall then inside.</TD></TR></TABLE>
Ha....Yeah...........I have a wire tuck...And no stock fogs or stock front bumper for that matter.........Urrrrrrrrrrggg..This is the only thing not wired on the car.
Ok here is a pic of my fog harness.
It looks a bit different than yours.
[IMG][/IMG]
Well hell image shack is not working....will add pic in a bit.
[IMG][/IMG]
Thanks for the help
Thanks for the help
