d16y8 block and d16z6 head question
Old Aug 24, 2006 | 02:48 PM
SC61HB's Avatar
Default d16y8 block and d16z6 head question
Before anyone says anything, I've already searched and there is no clear cut answer, some say this fits and others say another thing fits.
Here's my dilemma, I am in the process of putting a Z6 head onto a Y8 block and this engine is going into a '95 civic coupe automatic. The reason I am doing this is because my sister's Z6 motor, specifically the block, bit the dust. Since I have a spare Y8 block laying around, I figured I would bolt the original Z6 head, that is in perfect shape, to the Y8 block. I'm going to keep it OBD1, and reuse the harness that was on the original Z6 motor. Now for my questions:
- What headgasket do I need?
- What timing belt do I need?
- What water pump do I need?
- Will I have any troubles with CELs if I keep it OBD1 and reuse the P28 ECU?
- Will I be able to bolt up the original '95 civic ex automatic tranny to the Y8 block?
- Will all the motor mounts and accessory mounts (a/c, powersteering, and alternator) bolt up to the Y8 block?
If someone knows the clean cut answers to my questions please respond.
Thanks in advance.
Old Aug 24, 2006 | 02:50 PM
jaydem_ekizzle's Avatar
z6head gasket
z6 timing belt
z6 wp
no problems with cel as far as i know
yes
yes
Old Aug 24, 2006 | 07:48 PM
Brick Top's Avatar
Default Re: (jaydem_ekizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydem_ekizzle &raquo;</TD></TR><TR><TD CLASS="quote">z6head gasket
z6 timing belt
z6 wp
yes
yes </TD></TR></TABLE>
^^^what he said^^^
Old Aug 25, 2006 | 09:21 AM
SC61HB's Avatar
Default Re: (brick top)
Lol, I just got a pm from a guy that has actually done this and he said to use all Y8 parts.
Have you guys actually done this?
Old Aug 25, 2006 | 04:48 PM
Brick Top's Avatar
z6 timing belt
z6 wp
yes
yes ive done this. let me clear up a couple things.
88-00 d series head gaskets are all interchangable. vtec or not. the y8 is the best. get it.
timing belt needs to match the head. in think the y8 belt is the same as z6. both 1.6s
water pump needs to match the block. so a y8 pump. a d series rule
no check engine lights of my experiences
not too sure about the automatic tranny
all mounts and accessories will bolt up.
Old Aug 26, 2006 | 12:38 PM
ive had the same exact setup on 8lbs and it was fine
Old Aug 26, 2006 | 01:17 PM
Eyal 951's Avatar
timing belts are the same, get the y8 hg, same thing, better material. (metal)
I just put together a Z6 block, Y8 head motor, you can see the specs here:
You won't have an issue with the dizzy, or obd1/2 issues since your using the z6 head like I did, but you will have issues with the head studs, probably opposite to me. The Z6 studs will be too long, you need y8 studs. You may need a custom stud in one corner, I did. I was origionally told buy the studs for the head... WRONG! buy em for the block, as a result, I have a set of brand new ARP D16Y head studs FS. (95 shipped if you want em )
Other then that, I really don;t think you should have any issues, they are basically the same thing, especially the block. Feel free to pm me with any questions, I'll do my best to answer them.
Shane Rodgers
Mar 27, 2014 11:28 AM
Novtec4u
Jun 15, 2009 09:05 AM
001020
Feb 20, 2004 12:36 PM
bluedelsol
Jun 8, 2003 06:46 PM
