i bought dry ice to take tar off my car...need help!
Old Aug 24, 2006 | 02:15 PM
Fat Chick Magnet's Avatar
Default i bought dry ice to take tar off my car...need help!
i bought 12lbs of dryice today from a local ice store.
For those who have used dry ice to remove the tar in the trunk and under the seats........can you explain to me how to do it? I put the dryice on the tar for a minute and tried to take it off with a screw driver, but it didnt work. Is there a secret way of doing it?
Modified by dc2rtek at 3:28 PM 8/24/2006
Old Aug 24, 2006 | 02:19 PM
Tornadom's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">For those who have used dry ice to remove the tar in the drunk and under the seats... </TD></TR></TABLE>
Where is the drunk at in your car? They had better not be behind the wheel.
It takes a lot of work, and a lot of patience to remove the tar strips.
Old Aug 24, 2006 | 02:29 PM
Default Re: i bought dry ice to take tar off my car...need help! (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">Where is the drunk at in your car? They had better not be behind the wheel.
It takes a lot of work, and a lot of patience to remove the tar strips.</TD></TR></TABLE>
sorry i edit my post i mean trunk*
Old Aug 24, 2006 | 02:30 PM
trick_db's Avatar
what you do is break it into smaller pieces, and put it over the tar, let it sit for 15 to 20 mins. while doing that find a scrapper, like sharp 1 and start scrapping it
here is the link that can help you out, maybe searching it next time will help you out alot https://honda-tech.com/zerothread?id=525936
Old Aug 24, 2006 | 03:13 PM
Default Re: i bought dry ice to take tar off my car...need help! (trick_db)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">what you do is break it into smaller pieces, and put it over the tar, let it sit for 15 to 20 mins. while doing that find a scrapper, like sharp 1 and start scrapping it
here is the link that can help you out, maybe searching it next time will help you out alot https://honda-tech.com/zerothread?id=525936 </TD></TR></TABLE>
thanks a lot. would a screw driver flat head by any chance help?
Old Aug 24, 2006 | 03:27 PM
BOOSTED RIVAL's Avatar
air Impact hammer
Old Aug 24, 2006 | 03:42 PM
trick_db's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (BOOSTED RIVAL)
no, because is too small take forever, use something that wide and strong so you wont break it, but is not that hard, once you put on the dry ice, you will hear popping noise, and you can actually take it out with your hand, but just some part you need to use something to take it out, cause dry ice is not going to do all of them
Old Aug 24, 2006 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">no, because is too small take forever, use something that wide and strong so you wont break it, but is not that hard, once you put on the dry ice, you will hear popping noise, and you can actually take it out with your hand, but just some part you need to use something to take it out, cause dry ice is not going to do all of them</TD></TR></TABLE>
yeah its pretty easy i got some of it off in the trunk. im just waiting for my friend to get off so he can help me with the back seats. i dont have enough for the front i guess ill have to pick some more up later.
Old Aug 24, 2006 | 03:55 PM
trick_db's Avatar
is easy huh? told you already, not hard. is better if you do it at night, cause in daytime the heat will make it melt faster
Old Aug 24, 2006 | 04:27 PM
PrinceAli132's Avatar
How-to with dry ice;
http://www.team-integra.net/se...D=481
How to with heat gun;
http://www.team-integra.net/se...D=544
Ali
Old Aug 24, 2006 | 04:30 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">is easy huh? told you already, not hard. is better if you do it at night, cause in daytime the heat will make it melt faster </TD></TR></TABLE>
Dry ice doesn't melt, it goes through sublimation.
How much weight does this remove?
Old Aug 24, 2006 | 04:32 PM
trick_db's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (Sleeper Style)
yea it doesnt melt, but what the term for saying it disappear? dissolve? iono
but thinking 15lb all together, it just make your car look cleaner if you doesnt have the tar.
Old Aug 24, 2006 | 04:39 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">yea it doesnt melt, but what the term for saying it disappear? dissolve? iono
but thinking 15lb all together, it just make your car look cleaner if you doesnt have the tar. </TD></TR></TABLE>
Going from a solid to a vapor is called sublimation.
15lbs, eh? They must slather it with a lot of tar for it to weigh that much.
Old Aug 24, 2006 | 04:42 PM
trick_db's Avatar
if you wanan know the prove how much it weight, all the tar that been collect from eg was weighted at 15lbs.
Old Aug 24, 2006 | 04:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">
15lbs, eh? They must slather it with a lot of tar for it to weigh that much.</TD></TR></TABLE>
They are pretty liberal with it, but it is there to also lower road noise so it really isn't a bad sacrifice.
Ali
Old Aug 24, 2006 | 04:58 PM
KAWZ92DA's Avatar
Try soaking it in wd40. Thats what i used to get it off my paint. Just a suggestion.
Old Aug 24, 2006 | 06:20 PM
trick_db's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (KAWZ92DA)
that will not work, only method that i know of is dry ice, using wd40 will take off the paint, but it will not take out the tar
Old Aug 24, 2006 | 06:38 PM
Rtzx9r's Avatar
GDD 1%
make sure your work area is well ventilated- that stuff sublimates into carbon diaxider which will kill ya!!
Old Aug 24, 2006 | 06:46 PM
trick_db's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (Rtzx9r)
what is? dry ice? um i doubt it, i use about 14lb of it and all it did was sublimation didnt really do anything harm to me
Old Aug 24, 2006 | 07:14 PM
vactor's Avatar
http://www.youtube.com/watch?v=3Ys_Fjwi44w whatever you do, NOT this ...
Old Aug 24, 2006 | 07:18 PM
trick_db's Avatar
Default Re: i bought dry ice to take tar off my car...need help! (vactor)
what is that gonna do with everything? for stupidity
Old Aug 24, 2006 | 08:20 PM
KAWZ92DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">that will not work, only method that i know of is dry ice, using wd40 will take off the paint, but it will not take out the tar</TD></TR></TABLE> What ever man.. Good Luck
Old Aug 24, 2006 | 08:26 PM
trick_db's Avatar
im already done, im just helping people who need help.
Old Aug 24, 2006 | 09:42 PM
TheCheeseWedge's Avatar
my personal experience with the tar was in my crx i used a flat head screw driver and a hammer this was circa 2001 before i knew about honda-tech or dry ice method it took about 2 weeks after school every night so thats one way to do it
Old Aug 24, 2006 | 10:15 PM
i have like 5lbs of dry ice left...what would happen if u throw it inside a swimming pool?
