Disconnecting Rear Spoiler Brake Light
Old Aug 24, 2006 | 01:37 PM
depulse's Avatar
Default Disconnecting Rear Spoiler Brake Light
Where is the connector to disconnect the rear wing brake light?
94 EX sdn
Old Aug 24, 2006 | 02:36 PM
Ross 2.0's Avatar
In a Junkyard near you.
follow the wires down the trunk support and you'll find it just under the rear shelf i think.
Old Aug 24, 2006 | 02:37 PM
YeuEmMaiMai's Avatar
Default Re: Disconnecting Rear Spoiler Brake Light (depulse)
open trunk, left side where spoiler bolts to the car you should see the wire harness. follow it to where it plugs into the 3rd rear brake light harness.
Old Aug 24, 2006 | 02:52 PM
depulse's Avatar
Default Re: Disconnecting Rear Spoiler Brake Light (YeuEmMaiMai)
It looked like it ran down the support frame to the trunk lid and then into the trunk.
Is the connector in the trunk?
Old Aug 24, 2006 | 03:00 PM
Ross 2.0's Avatar
yes
Old Aug 24, 2006 | 03:05 PM
depulse's Avatar
Default Re: (MooGoCow3)
Tks,
I will pull back the inner covering in the trunk and look tonight
Old Aug 25, 2006 | 02:15 PM
depulse's Avatar
Default Re: (depulse)
Found connector, work Slick
Thanks for all the Help
chillerice
Lighting
Aug 9, 2014 07:19 AM
76 camaro car
Mar 30, 2012 01:14 PM
bobmugen
Jan 30, 2008 03:37 AM
mcbasspro
Jan 14, 2006 01:25 PM
