brake problem, pedal push to the ground?
when driving i approach a stop sign and when braking the brakes slowly move to the floor, like there is loss in pressure.
wtf my pads are mint and rotos are new, also have braided lines wtf
As spoon0313 mentioned check your fluid level and check for leaks.
I would defintely check the SS lines, cause people have had issues with them leaking. IMO they are not meant for street use and if you do decide to use them on the street i would inspect them every oil change for any unusual wear.
Here's some good links discussing SS brake lines;
https://honda-tech.com/zerothread?id=1199349
http://www.nsxprime.com/FAQ/Pe...s.htm
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK »</TD></TR><TR><TD CLASS="quote">brake master cylinder</TD></TR></TABLE>
Try reaching up to the top of you brake pedal, where it meets the firewall. Check to see if you feel any fluid. Sometimes a faulty Brake Master Cylinder leaks in that area, or so i've been told.
Ali
Ali
I had the same problem where i would be sitting at a light stopped with my foot on the brake pedal and it would just slowly push all the way to the floor. I had to get my brake master cylinder replaced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_R_Kills »</TD></TR><TR><TD CLASS="quote">cool, its for sure the cylinder, thanks again people!</TD></TR></TABLE>
So how were you able to determine it was the master cylinder? If you found a leak where was it leaking from? Sorry, im just curious.
Ali
Ali
good question ali, i will check with my mechanic. I never found a visible leak if that helps. Maybe it was leaking internally, like inside the cylinder/?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_R_Kills »</TD></TR><TR><TD CLASS="quote">good question ali, i will check with my mechanic. I never found a visible leak if that helps. Maybe it was leaking internally, like inside the cylinder/?</TD></TR></TABLE>
Thanks, im guessing it might be the piston/rod thats inside the master cylinder that might have gone bad or something.
Ali
Ali
david
Oct 31, 2005 11:02 AM
UnrealSpeed
May 17, 2003 01:45 PM
