im biulding my head help me out
alright so over today and tomorrow im gonna be building my head. i had the valves , springs, retainers, and rockers installed proffesionaly when i had my head milled and cleaned. so i need to install the cams and stuff. while ding this im gonna post pictures so that people can tell me if im doing anything wrong. thanks for your help if you have any questions please let me know.
**here are the first**
also... does anyone know off the top of their head what the TQ specs are for the cam gear bolt?
and when im oiling and greasing the cams for assembely should i just use motor oil or some spiceal engine assembly grease
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">how do i know where TDC it according to my cams and gears?</TD></TR></TABLE>
The white dots on the teeth point up and the lines on the teeth point toward each other.
It's a damn shame you're "building your head" with nothing more than Skunk2 Stage 1 camshafts. What a ******* waste. Might as well have gotten OEM Type-R or CTR cams and left the valvetrain alone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">also... does anyone know off the top of their head what the TQ specs are for the cam gear bolt?</TD></TR></TABLE>
Torque spec is 27 foot pounds, but more won't hurt anything as long as it's not more than 60
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">and when im oiling and greasing the cams for assembely should i just use motor oil or some spiceal engine assembly grease</TD></TR></TABLE>
Assembly lube. You can get some at any autoparts store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">and what are the TQ specs for the cam caps?</TD></TR></TABLE>
No thank you = no further information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">what do you mean by that? you dont want to help me out?</TD></TR></TABLE>
Archidictus gave you a ****-ton of information and you didn't even say thanks. That's what he is saying.
May i ask WHY you are installing the cams,cam caps, and rails? You have to take it all back out to put the head on the block. The head bolts are under the cams.....
well im sorry for not saying thanks Archidictus this one is to you THANK YOU SO MUCH FOR THE GREAT INFO it really did help a lot.
as for why im puting on the caps and rails, i just wanted to make sure eveything was gonna spin right before i put it on the block.
as for why im puting on the caps and rails, i just wanted to make sure eveything was gonna spin right before i put it on the block.</TD></TR></TABLE>
ok, i was just makin sure
1.) your cams are not aligned correctly. The DOTS face up and the LINES face each other level with the deck surface of the head.
2.) the small cam cap bolts are torqued to 7.2 ft/lbs and the bigger ones to 20 ft/lbs. Apply oil to threads before torquing.
EDIT:
3.) the cam cap plates are interchangable
4.) unless you're going to take pretty pictures, I'm not sure why you're assembling all this before it's on the car
EDIT:
thanks much
alright ill fix the cams and take pics in a few seconds.
i already put the cap plates/ rails on because somone already told me it didnt matter
and as for biulding the head not its so that i can make sure that every thing spins correctly befor i put it on the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote"> so that i can make sure that every thing spins correctly befor i put it on the block.
Good luck with that. You'll only be able to spin them with a ratchet and one at a time at that.
</TD></TR></TABLE>Good luck with that. You'll only be able to spin them with a ratchet and one at a time at that.
rebo0t
Oct 20, 2006 11:10 AM
