what do i need to get my aftermarket steering wheel and quick release to fit on my car?
Old Aug 24, 2006 | 09:08 AM
EKB18BPR3's Avatar
Default what do i need to get my aftermarket steering wheel and quick release to fit on my car?
::clarified::
i have a ebay steering wheel with nrg quick release. I thought thats all i needed to mount to my steering wheel shaft but i was wrong. Now im looking for a hub(?) to mount the quick release to the wheel shaft right? searching on ebay i found a momo one but for 60 bucks i dont want to make a mistake of getting a wrong one.
Modified by 98B00STED at 6:42 PM 8/24/2006
Old Aug 24, 2006 | 09:17 AM
Targa250R's Avatar
be professional
Default Re: what do i need to get my aftermarket steering wheel and quick release to fit on my car? (98B00ST
What hub adapter and/or quick release are you using?
Most 6-bolt hubs are 6x2.875" and will fit 6-bolt Momo and Sparco wheels. If you have a 6-bolt Nardi or Personal wheel (which have a 6x2.75" pattern rotated 90 degrees), you may need an adapter.
Old Aug 24, 2006 | 09:38 AM
EKB18BPR3's Avatar
i googled it and bought NRG short adapter. i was getting confused because the qucikrelease was called a hub and the hub that mounts to the steering wheel shaft was also called hub. the NRG short hub should work right? it better cuz i just coughed up 80 bucks for it.
Old Aug 24, 2006 | 09:55 AM
blksir2's Avatar
hub= is what attaches the steering wheel to the sterring columm.
quick release hub= is what attaches to you existing aftermarket hub(momo,hkb,etc) to separate the steering wheel.
hub spacer: goes between the hub and the steering wheel to extend the lenght of the steering wjeel closer to the driver...
hope that helped..
so basic set up will be: - aftermarket steering hub(momo,hkb,etc)especific for
your vehicle
-then goes the quick realease (nrg,splash,etc)
-last the steering wheel..
also you should have no problems using any momo, or hkb hub with your nrg quick realease or spacer...
Drizzy
13
Jun 5, 2012 03:21 AM
401tuner
Nov 2, 2007 02:26 AM
AlphaKennyWun
Honda S2000
Aug 29, 2006 05:33 PM
Exit Music
Jan 10, 2006 12:00 PM
nortrop
Sep 4, 2004 08:37 PM
