HOW DO I HOOK MY JDM DC2 PARKING SIDE LIGHT AND TURN SIGNAL?
Old Aug 23, 2006 | 10:28 PM
99delsol's Avatar
Default HOW DO I HOOK MY JDM DC2 PARKING SIDE LIGHT AND TURN SIGNAL?
RIGHT NOW I HAVE THE JDM FRONT END ON MY INTEGRA,AND WHEN I TURN ON MY PARKING LIGHT ITS JUST THE MIDDLE PARKING LIGHT IN BETWEEN THE H/L BEAM,I WANT TO HOOK UP THE SIDE MARKERS AND THE SIDE CORNERS SO IT CAN BE ON WHEN MY LIGHTS ARE ON.WHAT WIRES DO NEED TO HOOK UP ,ILL APPRECIATE THE INPUT THANKS
Old Aug 23, 2006 | 11:38 PM
Naruto's Avatar
Default Re: HOW DO I HOOK MY JDM DC2 PARKING SIDE LIGHT AND TURN SIGNAL? (99delsol)
ummmm....the light that's on.....is your city lights. Not your parking lights. the JDM teg did not have a socket that allowed the corner lights to be on ( usually seen as your parking lights ) and blink so you're probably going to want to re-do the wiring so that your city lights don't blink. You're also probably going to want to buy a 1157 socket for the corners and wire the sidemarkers in accordingly That way, when you turn on your parking lights, city lights and corners are on. When using the turn signal, only the sidemarker and corner lights blink.
Of course, if you don't mind the corner lights not being on when using the "parking lights", then keep the jdm 1156 socket that came with your front end and again...wire accordingly. There should be a wire in your harness already thats for the blinker...I forget which one it is at the moment, just wire that one to the sidemarker.
Old Aug 24, 2006 | 07:03 AM
Padawan's Avatar
Darth ModerVader
The side markers and corner lamps are not supposed to be lit with the parking lights on the JDM Integra. Your setup is wired correctly the way it is now.
Old Aug 24, 2006 | 07:16 AM
Desired_Speeds's Avatar
Default Re: HOW DO I HOOK MY JDM DC2 PARKING SIDE LIGHT AND TURN SIGNAL? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The side markers and corner lamps are not supposed to be lit with the parking lights on the JDM Integra. Your setup is wired correctly the way it is now. </TD></TR></TABLE>
thats the correct way then?
Old Aug 24, 2006 | 12:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: HOW DO I HOOK MY JDM DC2 PARKING SIDE LIGHT AND TURN SIGNAL? (Desired_Speeds)
Yes. When the light switch is turned on to the first click (the "parking light" position), only the city lights and the tail lights should be lit. The side markers and corner lights only illuminate when the turn signal or hazards are used.
Old Aug 24, 2006 | 09:57 PM
99delsol's Avatar
yeah i know that but i want the parking light and sidemarkers on with one click
Vampire2o9
Aug 12, 2009 12:11 PM
o0oz
Jan 3, 2007 08:22 AM
SiSpopu
Acura TL, RL & ZDX
Jul 22, 2006 02:46 PM
foofighter
Aug 24, 2003 10:24 PM
Big Teggie
Feb 11, 2003 12:40 AM
