I just want to make sure
They have different variants of the F22 -- f22ax (90-93) vs f22bx (94-97). The "x" is determind by the trim level, such as f22b1 in the 94-97 EX.
Intakes and exhausts are year specific, because of the shape of the body and engine bay. I'm not sure what parts would truly be interchangable. I believe intakes are. Headers are not interchangable because the exhaust ports are spaced differently.
the throttle body is different the bolt pattern is smaller on the 90-93 than the 94-97 accords if you stick with the 90-93 accord intake mani you can keep the same harness if you decide to go with the 94-94 intake mani you and will need to make small mods on it and the vacume lines as well
