NGK copper spark plugs vs. platnium NGK
time for new plugs, and I was thinking I could just get the copper ones, and instead of spending the $50 once a year, spend $5 every 2 months or so.
anyone else use copper plugs? are they good for the H22, as long as you switch them out within a reasonable time?
I'm going to assume by your tone that those numbers are very low. or high. not sure which
real question: are copper plugs ok?
and yes a drive a lot, but more importantly I drive hard
[Modified by JDM LUDE, 9:45 PM 4/26/2002]
Well, the platinums that come stock in a 5th gen aren't supposed to be replaced before the 105K service according to the manual - I had always been under the impression that coppers would go a solid 12-15K miles between changes...
Paul
Paul
hmm ok, didn't know that.
also, honda claims that the brakes will last 100,000 miles..... mine got somewhat close to that but didn't quite make it
so... its ok to run copper in the H22
[Modified by JDM LUDE, 9:54 PM 4/26/2002]
As far as I know - I ran them for a while, as did several other folks from PVN-G5 w/ no reported ill effects. Just change them at appropriate intervals...
Paul
Paul
MmmMmm...Coppers.........
I have used ngk coppers for years and have had not a single problem with them. They will last a year no problem, and cost a lot less too!
I guess there are a lot of different impressions on plugs, so that was mine.
lawrencelomanon
Honda CR-V & Element
Nov 15, 2017 10:37 AM
Ef Whore
10
Nov 27, 2002 05:37 PM
