I just want to make sure
Old Aug 23, 2006 | 07:27 PM
MadCityLude
Guest
Posts: n/a
Default I just want to make sure
Is the 91 Accord Ex Auto engine going to share the same components as a 95 Accord EX? Aren't they different somehow? I always see parts for accords split up from 90-93 and 94-97.
Modified by MadCityLude at 11:50 PM 8/23/2006
Old Aug 23, 2006 | 08:51 PM
MadCityLude
Guest
Posts: n/a
Default Re: I just want to make sure (MadCityLude)
ttt POST EDITED
Old Aug 24, 2006 | 08:49 AM
Chuckles99SH's Avatar
The motor mount points will probably be the same because you can swap motors with h22/f22/h23 thru the accords from 90-97 and use stock motor mounts. As for the engine bays being the same i would doubt it due to the changes in body styles thru those years.
Old Aug 24, 2006 | 09:17 AM
v4lu3s's Avatar
RTFM
they share SOME stuff, but they are diff engines. the moutns are different, the heads are different, the manifold are different. but the block casting is nearly the same, pistons rods and cranks will interchange.
they are split up 90-93 and 94-97 for th EXACT same reasons that ludes are split up by 88-91, 92-96, 97-01.
Old Aug 24, 2006 | 09:27 AM
MadCityLude
Guest
Posts: n/a
Default Re: (v4lu3s)
Major body styling modifications. Now I think I understand. Thanks for the help.
Old Aug 24, 2006 | 09:49 AM
v4lu3s's Avatar
RTFM
also changes to teh engiens themselves. admittedly there are a lot of shared parts, i would say that the change from 90-93 accord is similar to the change of the 4th and 5th gen ludes, ept the engine changes are more like the h23 to h33 differences.
Ron Pittman
Mar 15, 2016 04:17 PM
superfly831
Feb 9, 2012 11:51 AM
MadCityLude
Aug 24, 2006 05:45 AM
06gixxer
May 29, 2006 06:16 PM
typertn
Jan 15, 2004 03:50 PM
