Transmission Help....need answers ASAP
Old Aug 23, 2006 | 07:24 PM
defkid999's Avatar
Default Transmission Help....need answers ASAP
im trying to put transmission fluid in my engine and I told my buddy there is a small hole under the hood where you put the fluid..
Well we jack the car up and we take the right passengar tire out and tried to put the fluid on the side of the transmission....
There's no fluid in my tranny so now I'm stuck at home and I have to work in the morning...
Can anyone help me out on where I need to put the transmission fluid?
I wasted a bottle and a half already and I'm really pissed off....
No store has a funnel that has a small hole at the end....
I have a 94 civic si hatch with a d16z6 motor
Old Aug 23, 2006 | 07:25 PM
BauleyCivic's Avatar
Risky Business
Default Re: Transmission Help....need answers ASAP (defkid999)
https://honda-tech.com/zerothread?id=474557- Filling Tranny Through VSS
https://honda-tech.com/zerothread?id=536593- Filling Tranny Through VSS
Old Aug 23, 2006 | 07:36 PM
defkid999's Avatar
that works perfectly...thanks
Old Aug 23, 2006 | 08:26 PM
vlc92189's Avatar
or you can just use a tube that goes through your fill hole... and run it to the top
Old Aug 23, 2006 | 08:29 PM
turbociviccoupe's Avatar
easier through the vss...same difference
Old Aug 24, 2006 | 03:54 AM
EE_Chris's Avatar
Default Re: (turbociviccoupe)
Just make sure to take the actual fill plug out so that the excess spills out of it. That's how the proper level is obtained.
Old Aug 24, 2006 | 04:57 AM
Risky Business
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure to take the actual fill plug out so that the excess spills out of it. That's how the proper level is obtained.</TD></TR></TABLE>
Correct, I believe its 1.8 qts for SOHC, 2.5 qts for DOHC?
Old Aug 24, 2006 | 05:12 AM
slamedcivic's Avatar
Default Re: Transmission Help....need answers ASAP (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=474557- Filling Tranny Through VSS
i guess everyone learns something here i never knew that u could take the vss out and fill it there . thats awsome good post.
Old Aug 24, 2006 | 07:10 AM
Syndacate's Avatar
Default Re: (BauleyCivic)
Correct, I believe its 1.8 qts for SOHC, 2.5 qts for DOHC?</TD></TR></TABLE>
*Sigh*, u shouldn't know that information off the top of ur head :-P
Old Aug 24, 2006 | 12:45 PM
defkid999's Avatar
Default Re: (vlc92189)
wheres the fill hole
Old Aug 25, 2006 | 03:20 AM
EE_Chris's Avatar
Default Re: (defkid999)
Above (5-6") and to the left (1-2") of the drain plug.
Old Aug 25, 2006 | 06:18 AM
sauceja's Avatar
You can also use the vent tube with the cap on it. It has a fairly big opening to use.
I did that on my f22, make sure the fill bolt is out for runout and level measuring.
Worked perfectly for me after my pump broke.
F22 takes 1.8 as well.
Old Aug 25, 2006 | 06:29 AM
high-octane's Avatar
Default Re: (sauceja)
can you put the fluid through a dip stick?
97CWITR
Jul 18, 2011 08:05 AM
aoe_virus
12
Jun 20, 2005 06:05 PM
davidnguyen
Oct 29, 2003 06:24 PM
BerlinaAP2
Jun 20, 2003 10:14 PM
Pinhead
Jan 6, 2002 05:39 PM
