Rear sway bar rubbing against exhaust hanger
This is a near-future mod that I'll be doing, but here's the problem that some people are having right now.
It's a 6th Gen Accord with a Comptech 22mm rear sway bar.
What is an easy fix?
Insulation around the sway bar itself? Trim away at the very top of the rubber hanger?
Thanks guys.
Thanks guys.
longer exh hanger perhaps?
the way the omega mounts for the swaybar are, the sway bar is going to stay put and can't be adjusted, so the only solution is to make the exh hang lower, protect the swaybar with some sort of coating, and hope for the best.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey »</TD></TR><TR><TD CLASS="quote">protect the swaybar with some sort of coating</TD></TR></TABLE>
What do you recommend?
