Code 12 on ECU
Old Apr 26, 2002 | 11:53 AM
renahec's Avatar
Default Code 12 on ECU
I hope someone can point me in the right direction:
I have a 1994 prelude Si (H23A1). It recently started flashing the check engine light and when I read the code it was a "code 12, EGR Lift Sensor (Exhaust Gas Recirculation)
defective circuit or unplugged / defective sensor.
Now what do I do? is this something that is as easy as replacing a part?
Any help would be greatly appreciated.
Thanks.......................Hec
Old Apr 26, 2002 | 12:12 PM
Urban Business
Guest
Posts: n/a
Default Re: Code 12 on ECU (renahec)
http://hybrid.honda-perf.org/tech/codes.html
replace egr valve easy to do bolts in w/ 2 bolts
Old Apr 26, 2002 | 05:46 PM
renahec's Avatar
Default Re: Code 12 on ECU (TorteX)
Thanks for the reply; but how do I know which component is bad? there seems to be 3 components to the EGR system. 1) on the manifold 2) on the driver's side engine compartment(a little plastic canister with vacuum lines). 3) some sort of solonoid with a filter for a cap on it.
Is there a way to check to see which is bad?
Thanks again..............Hec
Old Apr 26, 2002 | 05:47 PM
renahec's Avatar
............By the way, all the vacuum lines look good and are connected
ef nine
Jan 27, 2010 09:32 AM
technine
Apr 18, 2007 10:51 AM
zcrx26
Mar 21, 2006 03:35 PM
DeDonDeRosa
Jul 1, 2004 01:28 PM
LazYRaCeR
Dec 5, 2003 12:05 PM
