HotSHot header for hybrid swap.
Old Aug 23, 2006 | 09:35 AM
hector85's Avatar
Default HotSHot header for hybrid swap.
so, im doing some research on headers. the header is going to be for my h22a civic.
hotshot makes a header for hybrid swaps. its designed only for civics with h22s. its a 4-1 equal length race only header. Features an 18" x 2-1/2" dia. straight open collector.
does anyone have this or heard anything about it? price is around 400.
Old Aug 23, 2006 | 11:09 AM
hector85's Avatar
anyone????
Old Aug 23, 2006 | 11:38 AM
IAluder95's Avatar
to tell you the truth i never heard of hotshot. arent the like pacesettler?
Old Aug 23, 2006 | 12:23 PM
93civic_sedan's Avatar
Might want to search for it. It is not the best header like an RMF,DTR, SMSP ect but it is better than DC, megan ect...I have an AN-R header with the merge collector that I got a good deal on used. If I didn't come across it here locally I was going to look into RMF....
Old Aug 23, 2006 | 12:28 PM
A Blue Lude's Avatar
Default Re: HotSHot header for hybrid swap. (hector85)
It's quite good. Too bad it doesn't fit Preludes...
Old Aug 23, 2006 | 12:39 PM
98vtec's Avatar
moderator emeritus
Default Re: HotSHot header for hybrid swap. (A Blue Lude)
hotshot has been around for a LONG time. They make pretty decent parts.
Old Aug 23, 2006 | 01:27 PM
mgags7's Avatar
hey yo hector, do you got a last name but cant pronounce it??
hit the search homes
Old Aug 23, 2006 | 01:47 PM
All-Motor-Junkie's Avatar
hotshot is a good header, id recomend over megan and dc and anr, i hade it before, only prob wont fit the h22 chasis, its made for a h22 in a eg chasis, youl have to cut some crossmember to fit it, or get a traction bar, makes more power then greddy and megan tho
Old Aug 23, 2006 | 02:46 PM
hector85's Avatar
Default Re: (93civic_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">hotshot is a good header, id recomend over megan and dc and anr, i hade it before, only prob wont fit the h22 chasis, its made for a h22 in a eg chasis, youl have to cut some crossmember to fit it, or get a traction bar, makes more power then greddy and megan tho</TD></TR></TABLE>
anyone else have experience or any feedback from this header?
Old Aug 23, 2006 | 06:12 PM
Slatelude's Avatar
Default Re: (hector85)
i'd ask in the "hybrid" forums as well, considering they dont make it to fit in the 'ludes.
K
Old Aug 24, 2006 | 02:27 AM
skunked5thgen's Avatar
I seen that header if not an exact copy in a issue of honda tuning a few months ago. They were testing high comp pistons and big cams on an h22 in a civic, that header made good power for them. I dont know what your motor plans are but that looks like a good choice. And like they said its much better than most headers out there, dc, megan, ect
Old Aug 24, 2006 | 07:43 AM
skunked's Avatar
Default Re: HotSHot header for hybrid swap. (skunked5thgen)
thats a good header for the price
Old Aug 24, 2006 | 09:01 AM
hector85's Avatar
thanks for all the helpfull info guys!
Old Aug 24, 2006 | 01:25 PM
Cyberdx16's Avatar
i currently have this header in my ej1 h22, the only thing that i really dont like about it is that its a 2 piece, and when connected it is held by 2 bolts and leaks some exhaust fumes. i ended up welding it together, but if u weld it, the studs to connect the header to the head have to be removed because of fitment, and u have to use bolts.
Old Aug 24, 2006 | 03:27 PM
hector85's Avatar
Default Re: (Cyberdx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 &raquo;</TD></TR><TR><TD CLASS="quote">i currently have this header in my ej1 h22, the only thing that i really dont like about it is that its a 2 piece, and when connected it is held by 2 bolts and leaks some exhaust fumes. i ended up welding it together, but if u weld it, the studs to connect the header to the head have to be removed because of fitment, and u have to use bolts.</TD></TR></TABLE>
whats your set up. and are you pleased with the power it makes?
Old Aug 24, 2006 | 04:15 PM
Cyberdx16's Avatar
3" intake, 2.5" exhaust w/o cat, 255 fuel pump
only ran 14.2, at 98 with a 2.2 60' on falk ziex, pretty much what i expected
Old Aug 24, 2006 | 04:32 PM
hector85's Avatar
other then the welding part, is there any other cons to this header??
Old Aug 24, 2006 | 04:33 PM
hector85's Avatar
do you have a picture of how it looks intalled?
Old Mar 6, 2007 | 06:09 PM
hector85's Avatar
Default Re: (mgags7)
what??? lol
bump****************
Old Mar 6, 2007 | 07:14 PM
The Destroyer's Avatar
Honestly, i have this header in my civic and it sucks hardcore... It sits right on the alternator, it is an immense pain in the *** to take in and out, oil pan clearance is nothing to write home about, the pieces where the header connects is starting to flake away and its left me with a slight exhaust leak and i dont think it makes great power. Do not buy this header, i think i am going to upgrade to the new camp1320 header...nothing but good reviews so far.
Old Mar 10, 2007 | 05:24 AM
hector85's Avatar
bump.
tempsohc
Nov 18, 2007 10:01 AM
blu3g
May 25, 2005 02:26 PM
JDMlyfestyle
21
Jul 5, 2004 07:53 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
sikcrx80
Aug 29, 2003 07:58 AM
