Attempting to swap a 92 h22a and tranny into a 97 lude
Hi All
I have a little bit of a dilemna, thing is I have two preludes both original JDM, a 92 h22a 5speed and a 97 h22a Auto I just purchased. I recently had the 92 block sleeved and built by Earl, and turbocharged. The dilemna is, I want to swap the whole engine and tranny from the 92 into the 97 prelude. I need to know what all is required to do this successfully. I know I need to get all the hydraulics for the clutch system along with the clutch pedal. what else would I need? I am also keeping the 92 manual (have an extra tranny), so swapping the parts is a no-no.
So basically what do I need to get?
The 97 lude is bone stock except for an exhaust.........the information below is for the 92 h22a
Engine and Drivetrain:
Benson Sleeves install/cylinder final bore/hone to 87mm
Benson balanced/micro-polished crank
CP Pistons 87mm 9-1 compression ratio & rings
Eagle Rods
ACL bearings
OEM Honda Gaskets
Balance Shaft removed
OEM Oil pump
Adjustable Cam Sprockets
Greddy Oil Catch Can
SPEC Stage 3 6 Puck Clutch
FIDANZA Lightweight Flywheel
Turbo Set-up:
Master Power T3/T4 Turbo... 50 A/R compressor .48 A/R turbine
Drag Gen 4 Cast Turbo Manifold
Custom 2.5” Mandrel Downpipe
Custom 1” Mandrel Bent Wastegate Dumptube
Precision 31.5x8x3.5 FMIC
Custom Intercooler Piping
Tial 35mm Wastegate .5 Bar
Greddy Type S BOV
Custom Filter Setup
2.5" JASMA Mandrel Exhaust
Electronics and Ignition:
Hondata S300
Greddy Profec BII Boost Controller
Apex-i Turbo Timer
Auto-meter Sport-Comp Boost Gauge
AEM UEGO Wideband
Auto-meter Sport-Comp Oil Pressure Gauge
8MM Spark Plug Wires
Denso Iridium Spark Plugs
Fuel:
Synapse Synchronic Fuel Pressure Regulator
RC Engineering 550cc Injectors
OEM Fuel Rail
Walbro 255 High Pressure Fuel Pump
Fuel Pressure Gauge
Suspension and Brakes:
TEIN Coilovers
KYB AGX Fully adjustable shocks
Earl Brake Lines
<U></U>
Eagle Rods
ACL bearings
OEM Honda Gaskets
OEM Oil pump
Turbo Set-up:
Greddy Type S BOV
Custom Filter Setup
Hondata S300
Apex-i Turbo Timer
AEM UEGO Wideband
Fuel:
OEM Fuel Rail
Fuel Pressure Gauge
TEIN Coilovers
Earl Brake Lines
<U></U>
Yes. I am doing the whole engine and tranny swap, runnning the hondata s300. Is the obdII>obdI harness, gear shifter, shift linkage and hydraulics for the clutch system all i am going to need?
I hope you are aware that there will have to be some rewiring? There is the crank sensor that needs to be rewired plus you have to deal with the injectors. On the 97 they are saturated and do not use a resistor box where as the jdm engine uses peak and hold and requires a resistor box.
Ok...If I am using the complete engine from the 92 h22a, engine harness and all with hondata S300. Wouldn't it be easier to just use saturated injectors and eliminate the need for injector rewiring? As for the crank sensor, can't I just change the connector. I am of the opinion that using the S300 would eliminate any such issues.
if you are going to use the engine harness as well then you have nothing to worry about, you wont have to touch anything, but I would still use the same injectors that come with that engine since they are 345cc compared to 290cc in the 97...
Like my original post stated, I am using the complete engine and tranny from the 92 h22a. I have a couple questions:
1) Are the connectors between the firewall and shock tower the same on the 92 and 97 ludes?
2) Do I just add the resistor pack on the firewall in the 97?
3)Mention was made regarding the crank sensor. Is that wired into the 97 engine harness?
4)Are the axles the same length on the 92 as the 97?
Well to answer #2, yes, that is all you would have to do as long as you use the harness from your 92 because there is a connector that goes right to the resistor box.
And to answer #3, yes it is wired into the 97, BUT, the crank sensor on the 97 is down by the crank where as on the 92 its in the dizzy. As long as you use 92 harness your fine, you wont have to mess with any wiring... When I did my swap I had to rewire the harness so those crank wires would go up to the dizzy.
I really couldnt answer the other 2 for you.
