Suspension & Brakes Theory, alignment, spring rates....
In need of HELP with suspension!!!!
Old Aug 23, 2006 | 04:12 AM
Janeshonda's Avatar
Default In need of HELP with suspension!!!!
Hi guys i drive a 1998 CIVIC EX. the last few weeks i have found my car tends to shutter at or over the 60 MPH mark, i had another driver drive it for a bit as i eyed the suspension and for some reason the rear pas. side wheel tends to hop like it is on a washboard road as the others do not. I took it into honda last week and all they wanted to say with out charging was odds are it's your suspension.. ok i see that but what maybe wrong. The spring itself is very stuff = to that of the others, no parts are bent or cracked. i am in need of help on this one as i do not want to cause any long term probs with my civic or anything more expensive. but i need to know soon what needs to be changed.
prob. off the bat my guess was the wheel was out of balance but once inspected found otherwise.
Rear pas. side wheel hops at any speed.
car shakes at or over 60 MPH.
any help will be great!
Thanks guys.
Old Aug 23, 2006 | 09:30 AM
PIC Performance's Avatar
Default Re: In need of HELP with suspension!!!! (Janeshonda)
Hello blown shock!
Old Aug 23, 2006 | 09:45 AM
Janeshonda's Avatar
Ok so if i was to change out the absorber that would do the trick? if so it looks like im running about $100.00 for an OEM (one). i cannot afford to change all four at this time .
Old Aug 23, 2006 | 10:13 AM
I'm guessing so. Still, having a tech look at it would be a good idea first, before you order a new shock.
wazep_civic
Suspension & Brakes
Dec 20, 2012 12:04 AM
flow_azn
Mar 18, 2005 01:21 AM
SohcVtecCrix
Feb 10, 2003 07:10 AM
