OEM Clutch... Why they say "not designed for racing purposes"
Old Aug 23, 2006 | 01:35 AM
VTEXTC's Avatar
Default OEM Clutch... Why they say "not designed for racing purposes"
My 1st and so far only trackday, i ended up having to trailer the ITR home.. roughly 200km, 2x car trailers later (dont ask.... lol ).
More than likely it was becuase i was a novice track driver, being to rough, and burning out out of every corner due to Kingstar POS rubber 8)
Probly got way way to hot.. or purely a combination of that and of n00bness.
As the 4th session went on, the gears were getting harder and harder to change, then nothing at all > Lots of smoke from the bellhousing, rolling off the track.
Heh.. this is why
All the pressure plate fingers are bent all sorts of differnt angles and ways, hard to see from the pic.
Lots and lots of clutch plate in the housing etc as you would imagine
Big :thumbsup: to Pizzaboy for lending a hand tonight dropping the box.
Will be replaced with an Excedy 5puk + H/D PP combo. Might hold up longer :-?
All in all
I PWND j00 OEM.
Or did it pwn me?
Old Aug 23, 2006 | 02:25 AM
machgo5go's Avatar
I guess like they always said " You want to play, You got to PAY!"
Modified by machgo5go at 7:03 AM 8/23/2006
Old Aug 23, 2006 | 02:43 AM
realis9's Avatar
Default Re: (machgo5go)
wow
Old Aug 23, 2006 | 04:30 AM
eg6ajk's Avatar
Default Re: (realis9)
doesn't look like a stock clutch thats for sure. Good luck!
Old Aug 23, 2006 | 04:53 AM
CW-ITR's Avatar
First, I never seen any OEM clutch that went bad like that in road racing. May happen in drag racing.
Second, that's ain't OEM clutch.
Old Aug 23, 2006 | 06:31 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (CW-ITR)
doesnt look OEM. I broke one just as bad in a 92 GSR!!
Old Aug 23, 2006 | 07:10 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: OEM Clutch... Why they say "not designed for racing purposes" (VTEXTC)
Almost 5,000 actual track miles on my original stock clutch and it still works fine.
You DO understand what it means to match revs, right?
Old Aug 23, 2006 | 08:03 AM
JDMSI's Avatar
Default Re: OEM Clutch... Why they say "not designed for racing purposes" (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha
Old Aug 23, 2006 | 08:35 AM
gogogomoveit's Avatar
Looks like some more practice on heel toe, my friend.
Old Aug 23, 2006 | 08:41 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Almost 5,000 actual track miles on my original stock clutch and it still works fine.
You DO understand what it means to match revs, right?</TD></TR></TABLE>
What....? Looks like the clutch understood just fine....
Just poking fun at the OP.... glad you shared with us your carnage.... fix it and get back out there....
Old Aug 23, 2006 | 06:30 PM
uNF$@#!'s Avatar
Default Re: OEM Clutch... Why they say "not designed for racing purposes" (RagingAngel)
holy crap you shredded it to pieces.
oem clutch or not, this sort of failure is not due to the clutch
replace clutch with oem type R clutch and do not ride the clutch on the track.
Old Aug 23, 2006 | 07:19 PM
Dat1BVtecN's Avatar
looks nutz,
Old Aug 23, 2006 | 08:40 PM
2HEKTK's Avatar
Default Re: OEM Clutch... Why they say "not designed for racing purposes" (Dat1BVtecN)
Far to rough on that car Bevan
Weve replaced 7 OEM ITR Clutch's in the workshop now but none that bad.
Old Aug 23, 2006 | 09:53 PM
VTEXTC's Avatar
Yeah sorry my bad, its an OEM replacement lol. I didnt mean it was the one Honda put in it.
And as i said, its more a combination of Noobness and in-experienced track driving.
I can heel toe just fine under normal conditions, but i was having a little trouble on the track. More to think about, and worry about.
I was getting the hang of rev matching again in that session, but a 2nd-5th mis-shift probly spelt doom. I can imagine a shitload of heat going into it having the revs drop from 8500, to whatever 5th would give you...
Also the tyres being used werent friendly, so it was hard to take lines, and keep lines. Alot of concerntration was going into brake points, and keeping it off the grass
All in all im not actually dissapointed. Its seen some hard drag racing in its life too. I went out knowing theres always the chance of something breaking under race conditions.
The 5puk is on its way. So will be at the next meet having another go for sure
Old Aug 24, 2006 | 05:01 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (VTEXTC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEXTC &raquo;</TD></TR><TR><TD CLASS="quote">
All in all im not actually dissapointed. Its seen some hard drag racing in its life too. I went out knowing theres always the chance of something breaking under race conditions.</TD></TR></TABLE>
If you'd been abusing the clutch beforehand, those pictures make sense...kinda
Old Aug 24, 2006 | 10:41 AM
tartje's Avatar
Default Re: (Ross)
whoah, that things had a number done on it!
i actually find it more of an effort to stop myself heel and toe-ing going into a corner now, under fast driving conditions such as track, it just comes naturally
Old Aug 24, 2006 | 03:46 PM
Opie's Avatar
Jeebus! I had 2 real hard track days, and about 10 Auto X's plus about 50k miles on my OEM when it finally went.
Old Sep 2, 2006 | 11:20 PM
VTEXTC's Avatar
Heres what its been replaced with
Have yet to install it, will be getting onto that Monday/Tuesday night. Should be shweet... once i get used to the "on/off" feel i guess.
Skimmed flywheel, decided against a new lightwieght one, as finances are non exsistant, and i dont know how long ill hang onto the ITR.. maybe a year or so.
5puk, solid center plate, uprated pressure plate. +26% over OEM, 1750lbs of biteover the 1300 standard.
4mm "off" to "on".. its gonna be interesting. Glad its not a daily thats for sure.
descartesfool
Jun 4, 2008 03:56 PM
98GSRDC2
Jul 8, 2006 05:12 PM
silentblackhat
May 14, 2005 11:58 AM
Asahi
Mar 4, 2003 03:14 AM
TypeSH
Mar 21, 2002 02:23 PM
