220hp154tqr LS/vtec
Testing water i planning on going H-series i am looking two get 4500 or h23a1 plus some cash (blue top) previous owner(myfriend) motor dyno 223hp 154tqr w/the new header car was tune on 91 w/ full muffler and I was tune on a dyno pack tune with 100octane. this motor only has about 25k, motor is in a ef four door i run 12.4@108(i put one of my time slip) check out the pic motor could do low 12's may be high 11s depend on what car it goes in and what tranny perfect for a street car
RedZone built -
84mm B18A1 block
IBspec Wiseco's 11.3:1
Probe rods
Polished and balanced rotating assembly
ACL Bearings
Type-r oil pump
Fadanza flywheel
RedZone Stage 3 clutch
ITR Transmission
B17A Head ported
Super-tech Valves
Super-tech Springs and retainers
Blox Type-B Cams
JG Cam gears
Blox intake manifold Port match
68mm RPM TB port matched
255LPH-HO in-tank fuel pump
Custom header 4-2-1
RedZone built -
84mm B18A1 block
Probe rods
ACL Bearings
Type-r oil pump
Fadanza flywheel
ITR Transmission
B17A Head ported
Super-tech Valves
Blox Type-B Cams
JG Cam gears
Custom header 4-2-1
civic93@8psi
11
Dec 13, 2009 05:06 AM
RedZone
33
Feb 16, 2005 09:34 PM
