help what is manufacturer code p1337? off a 98 dx hatch with d15 swap.
Old Aug 22, 2006 | 09:58 PM
s2k3_oc08's Avatar
Default help what is manufacturer code p1337? off a 98 dx hatch with d15 swap.
i had my friend scanned his 98 ek dx hatch he had this code p1337. what is that code? thanks!
Old Aug 22, 2006 | 10:02 PM
EGwhat!!!'s Avatar
Default Re: help what is manufacturer code p1337? off a 98 dx hatch with d15 swap. (s2k3_oc08)
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
search
Old Aug 22, 2006 | 10:06 PM
umop-apisdn's Avatar
1 4m 50 |337.
Old Aug 22, 2006 | 10:08 PM
s2k3_oc08's Avatar
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal how do u fix this? help thnks
Old Aug 22, 2006 | 10:22 PM
EGwhat!!!'s Avatar
Default Re: (s2k3_oc08)
to check it
the sensor is hidden by the timing belt cover you need to remove that to check it
locate the electrical connector for the sensor at the timing belt end of the engine. make sure the key is in the off position, then disconnect the electrical connector.
connect an ohmmetter between the 2 outer terminals in the connector (not the center terminal). there should be 1.6 to 3.2 k-ohms. if not, replace the sensor.
connect the ohmmeter between body ground and each of the sensor's outer terminals in turn (again, not to the center terminal). if the ohmmeter showss continuity, replace the sensor.
Old Aug 22, 2006 | 10:25 PM
s2k3_oc08's Avatar
thanks
AMseven
Honda Civic (2001 - 2005)
Sep 22, 2009 08:37 AM
soundbomber
12
Jan 12, 2008 04:35 PM
snatch
Dec 13, 2004 04:28 PM
igone916
Sep 15, 2003 05:26 PM
briangela
Nov 6, 2002 10:14 AM
