Is my bumper fixable? (hanging/dragging)
Somehow the previous owner of my db managed to mess up quite a few panels and lose quite a few screws/bolts. The air dam underneath my front bumper was hanging a bit low when I got the car. I recently put two plastic bumper clips in the holes underneath (there are no threads or way to bolt anything in). They're holding, but the bumper is still hanging low.
I'm getting ready to paint the car, should I just get a new bumper or is there a way I can fix this one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fliplm0de »</TD></TR><TR><TD CLASS="quote">id say cut it i cut my old one..since it almost pulled off my bumper getting out of the driveway
That's a scary thought. Where did you cut it? As soon as the black air dam part starts, or right after the bolt holes where it hangs by itself?
</TD></TR></TABLE>That's a scary thought. Where did you cut it? As soon as the black air dam part starts, or right after the bolt holes where it hangs by itself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 »</TD></TR><TR><TD CLASS="quote">If you cut it does it affect anything...ie debris getting up in the engine bay and possiblky damaging something?</TD></TR></TABLE>
it isnt necessary but i noticed the bumper is a lot more flimsy without it. with it there and mounted the bumper doesnt move as much
hahaha . i cut mine. i have nothing under to protect my stuff. good side it quit making the seccchh sechhh noise bad side-the whole front bottom radiator is vulerble//
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toshiro »</TD></TR><TR><TD CLASS="quote">That's a scary thought. Where did you cut it? As soon as the black air dam part starts, or right after the bolt holes where it hangs by itself?</TD></TR></TABLE>
Take a drill and drill very small holes in it (about 3-4 pairs all the way across), just big enough for a zip tie. Then grab a zip tie and put it through the holes - you will find something just about anywhere to grab on to (there are pre-drilled holes in the frame/underbody or you can even use the AC lines and such).
I hate driving and seeing someone with an undertray all flapping around - you can't notice when the car is parked but when you're in a driving position its pretty annoying
