Clutch? is this clutch right??
Old Aug 22, 2006 | 07:30 PM
Nicaraguense13's Avatar
Default Clutch? is this clutch right??
OK i was changing parts on my Flywheels and Clutch off my LS. My friend by mistake got my single cam Clutch to fit it between the plate and the flywheel ( the flywheel and Pressure Plate was off the motor). And well it Fit thinking that was the clutch the SIngle cam clutch fit but will it work???? i was going to buy a clutch but my single cam is basically new would the single cam Clutch work with the LS pressure plate and GRS flywheel on a LS with a B16 tranny??? Need help would save alot of money if it does
Old Aug 22, 2006 | 07:42 PM
ci_v_ic's Avatar
Default Re: Clutch? is this clutch right?? (Nicaraguense13)
i doubt it will but heres a way to check it. first take the clutch disk off and try to fit it onto the input shaft (spline) on the trans if it fits then it will work. then if that works take your clutch alignment tool and see if the clutch disk and flywheel bearing line up. check that and see.
Old Aug 22, 2006 | 07:53 PM
Thnks ALOT
SSJSubgeta
Oct 22, 2005 12:20 PM
vishyncsu
Oct 7, 2004 10:38 AM
danny98r
Jun 24, 2004 12:15 PM
98Luder
May 5, 2002 09:19 AM
