Question: rev limit low, CEL , car feels sluggish sometimes, serious help please
Old Aug 22, 2006 | 07:00 PM
bokals's Avatar
Default Question: rev limit low, CEL , car feels sluggish sometimes, serious help please
problem fixed.
Modified by Element. at 12:51 PM 9/13/2006
Old Aug 22, 2006 | 07:12 PM
Lewy. Dee Ayy's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (core3200tm)
the thing EATS threw gas like no tommarow...but that could be from the 02 sensor.
and..i would have got u in 2nd gear also but i let off
Old Aug 22, 2006 | 07:41 PM
Jhonny Ricer's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (WhiteOut)
#1 sounds like your injectors are dirty clean them with some brake cleaner throw em back in and see if its still throwing the injectors codes
#2 bad o2 sensor equals bad fuel mix you could be running lean or rich get them chacked and cleaned/replaced
#3 Egr could either be defective or just stuck open or shut from carbon deposits get some carbeurator cleaner and let it soak if it is electronic make sure that the electronic parts dont come in contact with the cleaner...
After doing all this runn through codes again if you arent throwing them anymore than your good if you are which ever ones are still being thrown may need to be replaced or serviced more extensivly
GL try these than post results
Old Aug 22, 2006 | 08:08 PM
bokals's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (Jhonny Ricer)
thank you man
any other help?
rev limit is at 7500 for some reason when it should be 8200
Old Aug 22, 2006 | 08:10 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by core3200tm &raquo;</TD></TR><TR><TD CLASS="quote">thank you man
any other help?
rev limit is at 7500 for some reason when it should be 8200 </TD></TR></TABLE>
you are throwing a CEL, you are limited because the ECU thinks something is wrong.
Old Aug 22, 2006 | 08:59 PM
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (Sleepy_Red_hat
yea since your throwing codes your ecu is limiting your engine to 7500 get the codes out and it should be gone if not come back and tell us
GL
Old Aug 22, 2006 | 09:41 PM
bokals's Avatar
i'm guessing since theres a cel there will be no vtec as well?
thanks for the help man
Old Aug 23, 2006 | 03:13 PM
up for my boy.
Old Aug 23, 2006 | 03:56 PM
beaneg6's Avatar
is your iab wired? if its not it could cause your car to be VERY slow...
Old Aug 23, 2006 | 06:52 PM
If it were a prob with the IAB he would be throwing a code for it I believe
Also I think that VTEC is suppressed while trowing codes but not sure all i can tell you is try these things than if prob with VTEC still persists post it up to us
Old Aug 23, 2006 | 09:46 PM
bokals's Avatar
how do i check IAB wiring?
Old Aug 23, 2006 | 11:43 PM
beaneg6's Avatar
there is a link on the top of this page...
Old Aug 24, 2006 | 02:26 AM
miahjera04's Avatar
do u have a vtec controller setup? or is the p72 chipped? if so, that could cause ur **** to not pull right, also, not rev to 8200. i had an si, and i bought a chipped p72 for it, converted to obd1 and everything. and the vtec engagement was set at 4600, which is really low considering it was all motor. so vtec didn't pull worth ****, almost was like it didnt pull at all. also, having bad o2's will make ur car run like ****, so i advise u to replace them immediately! o2's r the death of hondas
Old Aug 24, 2006 | 03:26 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (miahjera04)
If your O2 sensor isn't reading, you will get awful gas milage and shitty performance. Replace it.
Old Aug 24, 2006 | 10:09 AM
bokals's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (JDM_Ej)
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahjera04 &raquo;</TD></TR><TR><TD CLASS="quote">do u have a vtec controller setup? or is the p72 chipped? if so, that could cause ur **** to not pull right, also, not rev to 8200. i had an si, and i bought a chipped p72 for it, converted to obd1 and everything. and the vtec engagement was set at 4600, which is really low considering it was all motor. so vtec didn't pull worth ****, almost was like it didnt pull at all. also, having bad o2's will make ur car run like ****, so i advise u to replace them immediately! o2's r the death of hondas</TD></TR></TABLE>
Stock p72
no Vtec controller
but i will change the o2 sensor asap
Old Aug 24, 2006 | 10:22 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Are you sure you're reading those codes right, because a P72 ECU will NOT throw a code for anything EGR related. Is it a code 12? 12 is definately EGR valve lift, but I can't see how your P72 would even throw that ****.
No Integra GS-Rs had EGR, unless possibly you have an auto VTEC P72 ECU from a JDM GS-R auto, but it'd be throwing codes for lock-up since you've got a 5-speedtrans. with an auto ECU. Again if you've got a 5-speed P72 ECU it cannot throw a code for EGR.
Re-read those codes carefully and see what you've got.
Also even if the IABs are not hooked up the car stills pulls good, and they do not throw CELs of any kind.
Old Aug 24, 2006 | 01:35 PM
bokals's Avatar
http://www.youtube.com/watch?v=gSAiU1657Dk video to my Check engine light
maybe i'm reading them wrong
Old Aug 24, 2006 | 02:26 PM
bump because i just came from his house to try and recheck his codes..but i have ADD and i kept looking away....seriously..i couldent help it lol..
Old Aug 24, 2006 | 03:13 PM
92ehatch's Avatar
all i got was a repetitive code 22
the code went LONG LONG quick quick
which is 10 10 1 1 = 22
so what does code 22 = from the FAQ at the top it says VTEC pressure valve
Old Aug 24, 2006 | 04:13 PM
H22Ej2's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan &raquo;</TD></TR><TR><TD CLASS="quote">all i got was a repetitive code 22
so what does code 22 = from the FAQ at the top it says VTEC pressure valve</TD></TR></TABLE>
I had same issue but i was throwing another code with this one....once i fixed the other code this one went away....OTHER code was IAT temperature....Vtec probably won't engage correctly if you are still throwing the fuel injector code also
Old Aug 24, 2006 | 04:26 PM
92ehatch's Avatar
Default Re: Question: rev limit low, CEL , car feels sluggish sometimes, serious help please (H22Ej2)
from the video this is the only code he is throwing, therefor he should fix that one and continue from there.
he is just reading the codes wrong.
the codes will repeat over and over, and if you look at the video its a 22, not 3 diff codes
Old Aug 24, 2006 | 06:44 PM
bokals's Avatar
So my o2 sensor is fine?
now we narrowed it down to my VTEC pressure valve.
honda tech
io need to clean the vtec solenoid
Modified by core3200tm at 11:05 PM 8/24/2006
Modified by core3200tm at 12:32 AM 8/25/2006
Old Aug 24, 2006 | 07:59 PM
bump.
Old Aug 24, 2006 | 10:12 PM
bokals's Avatar
before bed
Old Aug 24, 2006 | 10:25 PM
saikouEF8's Avatar
fix this?
