To those who have replaced thier main relay (4 Gen)
How do you get to it to take it out? The closest I got to it was taking off the bottom plastic cover below the steering wheel. While I was under there I couldn't find a way to get it out. I know its screwed in up top but i don't know how to get to that screw. Any help would be appreciated.
The bracket kinda looks like an upside down T (if you use your imangination) and the cross part of the T keeps it from falling off. What you need to do is push the main realy up so it is above the cross of the t (up the shaft lol) and then once you do that, pull it in the z direction to pull it off the bracket.
does anyone know where i could get a new/possibly used main relay rz0139? everywhere online that i look is 50+
Guest
Posts: n/a
Take out the gauge cluster it is right behind where the tach is. I bought my relay from http://www.hondaautomotivepart...h.jsp but it was $50. I saw one on ebay for like $30. I just wanted to buy a new one so I hopefully never had to do this again. Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busyychild »</TD></TR><TR><TD CLASS="quote">kb58 what are you doing there?</TD></TR></TABLE>
Sorry for being a smartass. It's the ECU board for my mid-engine Mini. Wiring it that way made it Much easier to debug. The ECU goes behind the passenger seat and the main relay made sense going right there.
to kb, you are nuts.
to the op, i had to go as far as taking out the gauges to reach the 10mm bolt to actually unscrew it...a lot of people just unplug the harness and plug in a new one and leave the old one bolted on because they can't reach the bolt...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 »</TD></TR><TR><TD CLASS="quote">That's easy... it's right there!
CHEATER!!!
i like the above graphic as well. i just used a flap blade and pryed
CHEATER!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fish stick »</TD></TR><TR><TD CLASS="quote">to kb, you are nuts.
to the op, i had to go as far as taking out the gauges to reach the 10mm bolt to actually unscrew it...a lot of people just unplug the harness and plug in a new one and leave the old one bolted on because they can't reach the bolt...</TD></TR></TABLE>
you can pop the relay outta that bolted on housing, you did a lot of work for such a simple job....
brians356
26
Jul 3, 2015 10:04 PM
